  • 8
Message 1 of 12
Wifi speeds shockingly slow on superhub3
Hi all,
Our internet is like a yoyo, with speeds of over 200mb one moment and then down below 6mb the next. It's incredibly frustrating and certainly not the service we're paying for.
I'll post the logs below, but any ideas on how to get a consistent signal would be greatly appreciated.
139000000
Locked
Ranged Upstream Channel (Hz)
60300215
Locked
Provisioning State
Online
  • 8
Message 2 of 12
Re: Wifi speeds shockingly slow on superhub3
These are the downstream logs:
1139000000438256 qam1
21470000003.938256 qam2
31550000003.938256 qam3
41630000003.438256 qam4
51710000003.238256 qam5
6179000000338256 qam6
71870000003.238256 qam7
8195000000337256 qam8
92030000002.537256 qam9
10211000000237256 qam10
11219000000236256 qam11
122270000002.237256 qam12
13235000000237256 qam13
142430000001.737256 qam14
152510000001.737256 qam15
162590000001.537256 qam16
172670000002.237256 qam17
18275000000238256 qam18
192830000001.537256 qam19
202910000001.537256 qam20
21299000000237256 qam21
223070000002.537256 qam22
233150000002.536256 qam23
243230000002.436256 qam24
1Locked38.600
2Locked38.950
3Locked38.670
4Locked38.970
5Locked38.900
6Locked38.940
7Locked38.650
8Locked37.640
9Locked37.670
10Locked37.670
11Locked36.650
12Locked37.350
13Locked37.660
14Locked37.650
15Locked37.650
16Locked37.610
17Locked37.670
18Locked38.650
19Locked37.650
20Locked37.6150
21Locked37.3210
22Locked37.350
23Locked36.6110
24Locked36.310
  • 8
Message 3 of 12
Upstream logs
1602998504.575512064 qam1
2536999954.575512064 qam2
3394000004.55512064 qam4
4462000004.575512064 qam3
3ATDMA0000
4ATDMA0000
  • 8
Message 4 of 12
and the network logs
TimePriorityDescription
25/04/2020 21:30:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 10:12:43ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 01:17:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2020 00:46:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2020 16:21:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2020 04:14:15ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2020 02:47:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2020 04:36:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 01:09:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 07:40:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 05:12:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 04:48:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/04/2020 11:58:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2020 20:24:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2020 11:47:30ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 20:02:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 06:24:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 04:17:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 14:20:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.96K
  • 1.13K
  • 2.7K
Message 5 of 12
How are you speed testing and with what device?
  • 8
Message 6 of 12
Thanks for the reply.
I'm testing on my iPhone via the speed test app, plus on my Mac with Google and Speedtest website.
  • 20.96K
  • 1.13K
  • 2.7K
Message 7 of 12
You need to run a wired Speedtest to ascertain the issue is not with the speed coming to your property.
If that checks out ok then you need to look at ways of optimising your wifi - a mesh system, better router, wired AP’s etc.
  • 8
Message 8 of 12
Thanks, I'll give the wired test a go. I've assumed that as I sometimes get the full speed that it's coming into the property OK.
Buying additional kit to fix something that I'm already paying for seems strange to me.
  • 20.96K
  • 1.13K
  • 2.7K
Message 9 of 12
You don’t pay for wifi. You pay for the connection.
If the wifi doesn’t work in your property due to range etc. you need to optimise and fix it.
  • 8
Message 10 of 12
Ah, ok. I'm sitting right next across from the wifi hub (same room), so not sure range is the issue!
I need to order various connectors for a wired test. Will come back as soon as Amazon sort me out 🙂
