forumarchive,nothingtosee,
M4thj
Wifi speed
Hi there
Hoping you can help. I’m having some issues with my wifi speed. When running a speed test, it’s showing I’m ranging anywhere between 150 and 195 download speed but we aren’t seeing the benefit on our devices (freezing / buffering etc). Even when we are in the same room as the hub itself, it’s not much better.
Any thoughts / advice?
Matt
conman33158
  • 734
  • 66
  • 95
Superfast
Re: Wifi speed
Have you tried a factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
M4thj
Re: Wifi speed
Yes I did try that, last night I completely switched everything off but hasn’t made much of a difference. Coincidentally, the virgin app is saying it can’t find my hub 3 even though the internet is working, but is just slow
conman33158
  • 734
  • 66
  • 95
Superfast
Re: Wifi speed
Switching it off and factory reset are to entirely different things 🙂
