150564
Wifi speed
  • Paying for 200 getting 25 rang help line told the only guaranteed 100 don't  remember that in the advertisement on tv ? Been a customer  over 20 years the service is seriously lacking never even offered a service engineer to take a look ? Think its time to switch talk talk is even better than this .
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Wifi speed
VM do not, and never have guaranteed Wi-Fi speed or coverage.
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
150564
Re: Wifi speed
It varies from one day to next 118 to 26.9   for the last few months just not had chance to look into it also my tv upstairs cant not pick up wifi anymore you say vm dont guarantee speed why should i pay for a 200 package when im only receiving a 100 at best ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Wifi speed
 never said that VM don't guarantee speed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Wifi speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Wifi speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
