  • 13
Wifi speed slow and intermittent dropping when connected to works VM
I have been having real issues with my wifi speed and intermittently get kicked off when I'm connected to my work VM. I'm working in my conservatory which is a bit away from the hub, and so have taken my sons VM wifi booster from him (no more xbox for now) but still only getting 55mbps download which is a vast improvement on my use without the booster (average was about 6 or 7 mbps download).  When I check the speed test sitting right next to the hub, I once got 190 mbps download and 37mbps upload.  However, a quick check on the VM website says that for the M350 Fibre Broadband that I have, I should be expecting 368-381mbps with a guarantee of 181mps. I have only had this once - I presume that these speeds are not guaranteed for wifi?? Two questions 1) Does anyone know how I get an extra wifi booster from VM as seems that the chat/emails are not being responded to and so hopefully someone looking at this has some connections and 2) Should I be expecting better wifi?  I do pay a pretty hefty monthly bill to VM and so feel like I should, but maybe my expectations are misplaced.  I only moved the booster today (Sat) and so no idea if this will fix the work issue, but I truly hope so, or I'll need to start looking at an alternative supplier as this is not sustainable.
I've looked at similar posts and the stats that most people seem to have been asked to post are as below
  • 13
Re: Wifi speed slow and intermittent dropping when connected to works VM
I couldn't add the stats in the last post, so hopefully okay now
Cable Modem Status
Item
Status
Comments
291000000
Locked
Ranged Upstream Channel (Hz)
60299957
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
291000000
7.3
40
256 qam
20
2
139000000
7
40
256 qam
1
3
147000000
6.8
40
256 qam
2
4
155000000
6.4
40
256 qam
3
5
163000000
6.5
40
256 qam
4
6
171000000
6.8
40
256 qam
5
7
179000000
6.6
40
256 qam
6
8
187000000
6.5
40
256 qam
7
9
195000000
6.6
40
256 qam
8
10
203000000
7
40
256 qam
9
11
211000000
7.1
40
256 qam
10
12
219000000
7
40
256 qam
11
13
227000000
6.8
40
256 qam
12
14
235000000
6.8
40
256 qam
13
15
243000000
6.9
40
256 qam
14
16
251000000
7
40
256 qam
15
17
259000000
6.8
40
256 qam
16
18
267000000
6.8
40
256 qam
17
19
275000000
6.9
40
256 qam
18
20
283000000
7.3
40
256 qam
19
21
299000000
7.4
40
256 qam
21
22
307000000
7.3
40
256 qam
22
23
315000000
7
40
256 qam
23
24
323000000
7.1
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
4
0
2
Locked
40.3
5
0
3
Locked
40.3
5
0
4
Locked
40.9
0
0
5
Locked
40.3
6
0
6
Locked
40.3
6
0
7
Locked
40.3
6
0
8
Locked
40.3
14
0
9
Locked
40.3
21
0
10
Locked
40.9
5
0
11
Locked
40.3
5
0
12
Locked
40.9
6
0
13
Locked
40.3
5
0
14
Locked
40.9
6
0
15
Locked
40.9
5
0
16
Locked
40.3
6
0
17
Locked
40.9
5
0
18
Locked
40.3
6
0
19
Locked
40.3
5
0
20
Locked
40.3
5
0
21
Locked
40.9
6
0
22
Locked
40.3
5
0
23
Locked
40.3
5
0
24
Locked
40.9
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299957
4.2
5120
64 qam
1
2
39400058
4.2
5120
64 qam
4
3
46200021
4.2
5120
64 qam
3
4
53699983
4.2
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 13
Time
Priority
Description
07/04/2020 08:26:15
critical
No Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:47:5
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:46:35
Warning!
Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=*;CMTS-MAC=*CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:46:35
Warning!
TCS Partial Service;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:44:29
critical
07/04/2020 00:37:54
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:37:13
Warning!
Lost MDD Timeout;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:37:8
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:37:8
Warning!
RCS Partial Service;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 00:37:8
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*:;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 23:34:51
Warning!
06/04/2020 23:34:51
critical
06/04/2020 23:34:51
Warning!
06/04/2020 23:24:24
critical
06/04/2020 23:23:54
Warning!
06/04/2020 23:23:54
Warning!
Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 23:22:1
critical
06/04/2020 23:21:21
critical
06/04/2020 23:20:11
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 23:18:13
Warning!
RCS Partial Service;CM-MAC=*CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
