Quite often I get very slow speeds on my phone. I'm on the m200 plan but will often get between 10-15 mbps when I do a speed test. However, if I turn off the wifi on my phone and then reconnect, the speed goes up to a much more normal 140mbps.
The same happens on my daughters phone too, not just mine.
Why is this? And is there any resolution?
