emilyseg
  • 10
Wifi cutting out several times a day
Hi, please can someone help? See below:
12910000004.340256 qam20
21390000003.538256 qam1
31470000003.538256 qam2
41550000003.740256 qam3
51630000003.940256 qam4
61710000003.940256 qam5
71790000003.740256 qam6
81870000003.940256 qam7
9195000000440256 qam8
10203000000440256 qam9
11211000000440256 qam10
12219000000440256 qam11
132270000003.740256 qam12
142350000003.740256 qam13
152430000003.940256 qam14
162510000003.740256 qam15
172590000004.140256 qam16
182670000004.140256 qam17
192750000004.140256 qam18
202830000003.940256 qam19
212990000005.140256 qam21
223070000004.940256 qam22
233150000005.540256 qam23
243230000005.940256 qam24
1Locked40.92930
2Locked38.91620
3Locked38.98270
4Locked40.31470
5Locked40.32650
6Locked40.91290
7Locked40.31640
8Locked40.316017
9Locked40.31450
10Locked40.31120
11Locked40.31130
12Locked40.31940
13Locked40.31810
14Locked40.91460
15Locked40.92140
16Locked40.96970
17Locked40.92400
18Locked40.92080
19Locked40.92420
20Locked40.32650
21Locked40.32590
22Locked40.92890
23Locked40.33350
24Locked40.3290
0
12580023346512016 qam6
23940012746.5512016 qam4
34620016246.8512016 qam3
43260033646.3512016 qam5
1ATDMA0010
2ATDMA0030
3ATDMA0040
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID49584
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID49583
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
emilyseg
  • 10
Re: Wifi cutting out several times a day
19/07/2021 16:55:51Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 22:23:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2021 10:09:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2021 21:26:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2021 08:24:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2021 10:21:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2021 08:00:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2021 10:21:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 00:01:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2021 22:21:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 21:16:14noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2021 20:02:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2021 17:43:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 06:38:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 21:28:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 21:28:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 02:29:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/06/2021 01:58:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 15:26:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 13:58:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 23.86K
  • 2.53K
  • 4.33K
You haven't said why you want someone to look at this? What issues are you experiencing?
Meanwhile - your up qam's are all 16 - should be 64 (but that "might" be ok).
Can you do a pinhole reset of the Hub and see if they revert to 64.
Note that a pinhole reset on a Hub3/4 can be a bit problematic - so do it (again) EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections (leave the co-ax connected) and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub
See if that helps
emilyseg
  • 10
hi, as above the internet keeps cutting out.
I will try as you have suggested, thank you
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
The poor upstream modulation is accompanied by quite a few T3 timeouts.  One of the downstream channels has uncorrectable (post-RS) errors breaking through.  Depending on how fast those are cropping up that may be a problem.  I suspect that a technician may be needed.
Paulina_Z
  • 1.06K
  • 33
  • 67
Hi @emilyseg,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're experiencing ongoing drop outs with your connection. This is definitely not the service we want our customers to experience.
I was able to locate your account and run some further checks for you. I cannot see any area issues that would be impacting your connection, nor any power level issues that could be causing this either.
In this case, I would advise you to complete a Pin-Hole Reset as @jbrennand suggested and set up a BQM chart to keep an eye on your drop outs. One the BQM is set up, please monitor your connection for 24 hours, so we can see how your connection is doing.
Please keep us updated on how you get on.
Paulina_Z
