Smokey_04
Wifi Speed
Wifi speeds are significantly lower than the 100meg plan coming in c12mb downloading.
This has been constantly reducing after moving hub with speeds taken facing the hub which is causing issues working from home and kids using wireless connections.
  • 24.06K
  • 2.54K
  • 4.37K
Re: Wifi Speed
To check whether it is just a wifi issue or a VM connection issue, can you do the below. There are different routes to sorting the issue for those two possibilities
______________________________________________________________
Connect a computer/laptop, with up to date network card drivers, via a known good and working Cat5e (or better) ethernet cable, plugged directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
