Firstdmc
  • 14
Message 1 of 14
Wifi Speed Issues
Hi, hope someone can help.
Not had any issues with wifi speed for ages but in the last day my speed has dropped from 250mb to 10mb
Tried reset etc but doesn't resolve. Nothing has changed in the home for this to happen and frustrating when the virgin hub scan etc says everything is "great"
Can someone help me to check.
Thanks in advance.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Wifi Speed Issues
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Firstdmc
  • 14
Message 3 of 14
Getting around 91MB using either with nothing else connected.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 14
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Firstdmc
  • 14
Message 5 of 14
Firstdmc
  • 14
Message 6 of 14
1331000000-0.438256 qam25
2235000000-1.538256 qam13
3243000000-238256 qam14
4251000000-238256 qam15
5259000000-1.538256 qam16
6267000000-138256 qam17
7275000000-138256 qam18
8283000000-0.738256 qam19
9291000000-0.738256 qam
Firstdmc
  • 14
Message 7 of 14
15369998847.5512064 qam2
23939998346512064 qam4
34620000047.5512064 qam3
46029997647.5512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Firstdmc
  • 14
Message 8 of 14
21/10/2020 21:21:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 16:46:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 16:46:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 16:46:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 16:43:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Firstdmc
  • 14
Message 9 of 14
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 14
Which Hub do you have ?
That doesn't look like the proper number of lines and the second table is missing.
