Hi @Louay
Please try following the instructions <<< here >>>
If that doesn't work you can also call by calling 0800 064 3850 to order a pod (they will only send out one at a time, and there must be an interval of at least one week before a second order will be accepted)
Call around 8am if possible when lines first open and are least busy.
They are free if you are on the Gig1 package, or Ultimate Oomph, or on a Volt bundle, however if you are on any other package then they are £8 a month.
A member of the Forum Team may pick this up for you in a day or two.
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
