AimieJ
  • 11
Message 1 of 14
WiFi speeds vary on device
Hi. New customer.
having issues with WiFi speeds on my iPhone I get ~200mbps. But on my laptop I only get ~10mbps. (Note they’re next to each other and I’m about 2M from the hub)
I ran diagnostics and got the following back:
If you still think something is wrong, please check the following
1
Gateway IPv4 address is valid.
2
Your broadband connection is working.
3
Your broadband connection is ready.
4
The temperature of your Hub 3.0 is normal.
5
The device **:**:**:**:**:** has low signal strength, please move it closer to Hub 3.0.
6
7
8
Please place your WiFi device near the Hub 3.0.
AimieJ
  • 11
Message 2 of 14
Re: WiFi speeds vary on device
Cable Modem Status
Item Status Comments
402750000
Locked
Ranged Upstream Channel (Hz)
46200014
Locked
Provisioning State
Online
AimieJ
  • 11
Message 3 of 14
14027500007.940256 qam30
22027500008.140256 qam9
3210750000838256 qam10
42187500008.140256 qam11
5226750000840256 qam12
62347500007.940256 qam13
72427500007.840256 qam14
82507500007.640256 qam15
92587500007.640256 qam16
102667500007.640256 qam17
112747500007.640256 qam18
122827500007.640256 qam19
132907500007.640256 qam20
142987500007.940256 qam21
153067500007.840256 qam22
163147500007.940256 qam23
173227500007.840256 qam24
183307500007.940256 qam25
193707500007.940256 qam26
20378750000840256 qam27
21386750000840256 qam28
22394750000840256 qam29
234107500007.940256 qam31
244187500007.640256 qam32
1Locked40.390
2Locked40.980
3Locked38.960
4Locked40.960
5Locked40.940
6Locked40.3110
7Locked40.380
8Locked40.380
9Locked40.360
10Locked40.360
11Locked40.380
12Locked40.370
13Locked40.9110
14Locked40.360
15Locked40.9170
16Locked40.9170
17Locked40.380
18Locked40.980
19Locked40.320
20Locked40.390
21Locked40.970
22Locked40.3110
23Locked40.360
24Locked40.3100
AimieJ
  • 11
Message 4 of 14
14620001440512064 qam3
23259996938.5512064 qam5
33939998140512064 qam4
45370003940512064 qam2
3ATDMA0020
4ATDMA0000
AimieJ
  • 11
Message 5 of 14
15/12/2020 09:25:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 03:56:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 09:54:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:08:38criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:06:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:04:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
  • 26.49K
  • 2.7K
  • 4.91K
Message 6 of 14
As the iPhone is getting full speeds and the laptop isn't - that's the place to look first.
Does it have an "old" wireless card in it that is limiting speeds - perhaps it has failed, or the drivers need updating. What does it say in the settings about its spec? Can it connect to the 5GHz band or is it 2.4GHz only perhaps?
AimieJ
  • 11
Message 7 of 14
It’s not just the laptop (although I’ll see if I can check those things).
The PlayStation was getting much lower speeds also (even when connected via Ethernet cable)
Husband’s laptop was much slower too. I put this down to it being in a different room but I live in a small flat!
AimieJ
  • 11
Message 8 of 14
I checked the driver for updates and all looks fine
AimieJ
  • 11
Message 9 of 14
Performed an additional check to make sure it supports 5ghz - looks like it does
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac
AimieJ
  • 11
Message 10 of 14
d2a9f419c2951c04aaf6dbe7c820d43c80d78e88-16-12-2020
Tags (1)
