on 04-01-2023 21:17
Wi-Fi speed keeps dropping - done all the resets etc. and the speed goes up but then drops again by around 90%
on 04-01-2023 22:02
How about wired devices?
on 05-01-2023 07:00
There are no wired devices
on 07-01-2023 14:58
Hi Vfa69, thanks for posting and welcome to our community.
Sorry to hear that you're experiencing slow speeds via your WiFi connection. When you say resets, do you also mean pin hole resets? This is where you take your hub back to factory settings, as per here. I would also recommend doing a speed test to your hub. This would help determine if this is an issue with the internet as a whole, or WiFi only. You can do this here. For future reference you may wish to check our hints and tips: here and here. And you may also wish to download our connect app. This would allow you to scan your property to optimise the wireless network and if needed order our pods. However, as you've reached out to us, I would like to take a closer look on your behalf. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
