Blitzed
WiFi speed
We just installed a new WiFi hub Today as our old one was worn out. We upgraded from 200mps-500
how long until the WiFi speed increases?
the speed is the same or worse and it’s worrying since I’m a gamer and my PS4 doesn’t seem faster neither my iphone
Tags (4)
Andrew-G
  • 6.1K
  • 1.07K
  • 2.57K
Re: WiFi speed
For probably the majority of wireless devices you won't see any improvement, because they may already be operating at the maximum real-world speed given their specifications.  Some high spec devices will be able to operate close to or even above 500 Mbps, but they are a small minority.
In terms of the question "has my cable connection speed been upgraded?", connect to the hub, click on Check router status, and then on the Configuration tab.  Look for the field for Maximum Traffic Rate in the Downstream section.  That'll show your connection speed in bits (not mega bits) per second.  Knock off the last six digits and you should see a number above 500.  If you're seeing something like 221, then the configuration upgrade hasn't yet been sent to the hub.
  • 15.91K
  • 687
  • 1.56K
Re: WiFi speed
How peoples minds work speed increase I will get my speed by wifi because thats what I'm paying for! nope welcome to the real world.
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Re: WiFi speed
A gamer would use a wired connection
