Guildyno11
WiFi speed inconsistent rarely above 30mb should be 100mb ?
Got hub 3 it's Reuter is useless is the hub 4 better seriously considering leaving don't know why I should be forced to buy another Reuter to get the speed I'm paying for ??
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: WiFi speed inconsistent rarely above 30mb should be 100mb ?
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Guildyno11
It's fine on ethernet cable it's the WiFi to rest of house one day 11mb next 20mb then 15mb reboot it sometimes get 90mb next day back to 20mb am I wasting my time with the hub 3 Reuter ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
Look at the VM Supplied Hub, it is cheap and has poor Wi-Fi built in, then look at the VM supply 'Booster' to help the signal; do you think they will pay out good money for decent 'Boosters' that they are going to give out for free ?
Many people have accepted that the VM Wi-Fi is very poor and have spent money on third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
If you remove all the internal walls, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from a VM Hub.
