  • 626
  • 38
  • 40
Message 21 of 36
Re: WiFi problems again
Hi davef1uk,
I can see another agent commented on your other post from the 25th February.
Cheers.
Ryan_N - Forum Team
  • 49
davef1uk
Message 22 of 36
Had to reboot the router last night, then no device could connect saying obtaining IP and it was like this for an hour. Did another reboot, rebooted devices and finally connected .
Once connected. Did a speed test which failed to connect then 4th attempt it connected .
I will be phoning cancellations as Virgin are never going to fix my problem it seems .
No internet, try unplug and wait 10 seconds for the miracle to happen!
  • 1.6K
  • 68
  • 117
Forum Team (Retired) Joe_F
Message 23 of 36
Hello davef1uk,
I'm sorry to hear you have had intermittent service.
This is clearly not the type of service we promised.
I understand how you feel about cancelling your service.
How are things going since your last post? We would love to know
so we can help you further.
Have you already spoken to anyone about your cancellation?
Let us know, so we'll know how to move forward.
-Japhet_F
  • 49
davef1uk
Message 24 of 36
Apologies don't fix things . But thank you .  Action would be nice .
Nothing has or will ever get better.
New cable, new router. But still same crappy service.
Last time I phoned cancellations they offered me 200mbps in hope that will fix my issue .
I find it crazy no one at Virgin knows what is actually causing it.
It's pretty obvious to me. If the cable is fine, router too, it has to be the network . Be it some one along the line causing it.
Could be a service they have discontinued but the end is open.
I would just like this fixing .
  • 27
Forum Team (Retired) Japhet_F
Message 25 of 36
Hi Davef1uk,
It's a shame your still having the same issue. We do appreciate your feedback though. Let me just ask some few questions in order to identify
the resolution to your WiFi issue.
Can you confirm what hub are you currently using?
What are the light status on the equipment?
If you are using the using the hub 3 you might wanna check this thread as it helped some of our customers.
In case this doesn't work, please get back to us to we could
look further in to your connection.
-Japhet_F
  • 10.67K
  • 1.09K
  • 1.7K
Message 26 of 36
Dave, it looks like you are being given the run around by the Mods and getting no real no active help. So I would Call “Retentions” on 150 or 0345 454 1111 - options 1-1-4-5 "Thinking of leaving" - they are open Monday – Friday, 8am - 8pm and on Saturday from 8am - 6pm. – [early is best!]) you will get a UK call centre who are more flexible. Tell them you want to know when your contract ends and can leave without penalty (check it first so you actually know) and tell em you want to leave for Sky/BT because of these continually unresolved problems - and they at least will try and sort it for you or give you best information (as it’s actually their job to keep customers).
  • 13.5K
  • 1.05K
  • 3.16K
Message 27 of 36
imo you need to draw a line under the posts above and need to start again
VM are whistling in the wind - how is this that or the other - links to other threads - maybe they should try and help instead of posting replies that do nothing other than add to their post count
so if you are up to another try post the facts as they are today - new cable from the cab? - new hub? - anything else
a full reset sometime in the past - did you then turn off smart wifi and split the bands?
and repost the upstream and downstream levels
then sit back and wait for VM to offer their chat or ask you how things are
that apart hope other users can make some suggestions
____________________
Tony
  • 962
  • 45
  • 129
happywithmy350
Well-informed
Message 28 of 36
What about these new extenders they are doing?
  • 10.67K
  • 1.09K
  • 1.7K
Message 29 of 36
What new extenders ? Got a link ?
  • 57
Forum Team (Retired) Ning_Q
Message 30 of 36
Hi, happywithmy350.
I see you're curious about the boosters. The information on this link will help.
Alternatively, if you'll need more information about them give the team a call on 03454541111, another option is to send a text on 07533051809 between 8am and 7pm Mondays through Fridays. I can assure you they'll be glad to assist.
Ning_Q
