@Davymck wrote:
The booster I have isn’t from virgin, are they the best ones to use then ? I will try what you said and hardwire it with Ethernet cable, appreciate it 👍
Which ones do you have? They may not be powerline ones?
The VM ones are just rebranded/flashed Netgear kit.
The powerline adapters should still work further away from the vicinity of the HUB and a wired connection, even over powerlines, should be more consistent.
You've got nothing to lose trying it as you can always move it back!
