Cassandle
  • 16
Message 1 of 28
WiFi connection is intermittent, slow speeds
We have a Hub 3, and have done for a few years.
The WiFi signal is dropping out multiple times a day. This is particularly frustrating as I’m working from home and relying on apps like Zoom. The WiFi grinds to a halt for a few minutes before getting back to normal.
It happened last night whilst I was watching Netflix and YouTube (multiple times in the space of a few hours). I ran some speed tests and was getting speeds as low as 1mbps, which is obviously not enough to stream videos.
I’ve restarted the router, moved it to a more open space in the room and scanned the house using the Virgin app.
I’m getting a bit fed up of not having a stable connection whilst paying £41 p/month, and it seems to be impossible to actually speak to anyone at Virgin, so am posting here for ideas as to what to do. Happy to do some additional troubleshooting, but the next step - if that doesn’t work, will be to change provider.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 28
Re: WiFi connection is intermittent, slow speeds
Welcome to the Trials & Tribulations of Wi-Fi
VM do not, and never have guaranteed Wi-Fi speed or coverage.
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something, somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
If you remove all the internal walls, water, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from an ISP Hub.
Just a few things that can affect Wi-Fi in the average home …
Blockage (visible) …
Mirrors, furniture, fish tanks, people, radiators, walls, flooring / ceilings.
Interference (invisible) …
Cordless phones, baby monitors, microwave ovens, fridges & freezers, TVs, next doors Wi-Fi and Wi-Fi equipment, DAB transmitters, the list is endless.
My VM Hub 3 Wi-Fi went into meltdown when the local authority / police CCTV camera on the lamppost adjacent to my house was used.
Many people have accepted that the VM Wi-Fi is poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 28
What is your connection like using a direct connection with a Cat 5E or better ethernet cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook ?
Cassandle
  • 16
Message 4 of 28
Hi, thanks for getting back to me and apologies for the delay in responding. Been a busy few days.
I’ve plugged in my old MacBook to the Hub using an Ethernet cable and will take readings when I’m experiencing drop-out via WiFi.
Early readings are as follows (I have no idea how to interpret these readings), but I will report back when I have results during a drop-out
TimeDownload (Ethernet / WiFi)Upload (Ethernet / WiFi)Ping (Ethernet / WiFi)
15:1088.82 / 81.59.8 / 10.08 / 12
15:1143.78 / 24.92.6 / 6.218 / 11
15:1284.17 / 91.76.11 / 9.978 / 9
15:3769.99 / 34.08.9 / 9.389 / 11
15:3862.38 / 38.96.12 / 7.3110 / 11
15:3965.74 / 42.27.77 / 6.928 / 9
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 28
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 28
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Cassandle
  • 16
Message 7 of 28
Here you go
My BQM
Cassandle
  • 16
Message 8 of 28
 Hope this is right...
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1330750000740256 qam25
22587500006.340256 qam16
32667500006.340256 qam17
42747500006.440256 qam18
52827500006.640256 qam19
62907500006.640256 qam20
7298750000740256 qam21
83067500006.840256 qam22
9314750000740256 qam23
10322750000740256 qam24
113707500007.440256 qam26
123787500007.540256 qam27
133867500007.340256 qam28
143947500007.140256 qam29
154027500007.140256 qam30
164107500007.340256 qam31
17418750000740256 qam32
184267500007.140256 qam33
194347500006.840256 qam34
204427500006.940256 qam35
214507500006.940256 qam36
224587500006.940256 qam37
234667500006.540256 qam38
244747500006.340256 qam39
1Locked40.314213
2Locked40.91280
3Locked40.31290
4Locked40.31380
5Locked40.91440
6Locked40.31390
7Locked40.91560
8Locked40.31630
9Locked40.91690
10Locked40.31510
11Locked40.91490
12Locked40.91620
13Locked40.91630
14Locked40.31710
15Locked40.31780
16Locked40.31650
17Locked40.31720
18Locked40.31830
19Locked40.31700
20Locked40.31760
21Locked40.31640
22Locked40.31570
23Locked40.31730
24Locked40.91650
Cassandle
  • 16
Message 9 of 28
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
43.5
5120
64 qam
4
2
46200009
43.5
5120
64 qam
3
3
53700021
45
5120
64 qam
2
4
60300000
45
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
iyewrkldJKDHSUBsgvca69834
SFID
6760
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
6759
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Cassandle
  • 16
Message 10 of 28
Time
Priority
Description
10/01/2021 10:13:36
critical
08/01/2021 16:54:5
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 16:21:56
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 14:38:32
critical
08/01/2021 08:01:30
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 08:01:30
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 02:55:25
critical
05/01/2021 02:38:24
notice
05/01/2021 02:38:24
Error
02/01/2021 06:59:16
critical
02/01/2021 04:52:9
notice
02/01/2021 04:52:9
Error
02/01/2021 04:52:7
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 13:28:11
critical
28/12/2020 19:02:56
notice
28/12/2020 19:02:56
Error
28/12/2020 18:29:26
critical
28/12/2020 12:22:7
Warning!
27/12/2020 05:41:58
critical
26/12/2020 13:46:33
Warning!
