on 20-09-2021 12:01
I'm a M100 customer and I've just done a wired speed test and it hits 100mbps no issue.
All of a sudden over the past week the WiFi speeds which used to be at 100mbps has fallen away:
PS5 - 10mbps
Laptop - Between 20 - 40mbps
At present there are only two devices connected and both are getting 20mbps.
Nothing has changed and every device used to get 100mbps. Any ideas?
on 20-09-2021 12:07
on 20-09-2021 12:49
Fair point - some of those reasons could explain why I got 100mbps all over the house and now it's dropped to 20mbps.
100mbps over the wired - what I class as the normal speed. When I disconnect and go wireless - literally taking a step away from the router the speeds falls - last three wireless tests 20mbps, 60mbps and 30mbps.
on 20-09-2021 13:04
20-09-2021 13:47 - edited 20-09-2021 13:53
Cheers will give it a go tonight and report back.
FYI - I powered down the router and then turned it back on after a couple of minutes.
Mobile Wireless - 100mbps
Laptop Wireless (next to mobile) - 50mbps
PS5 - need to test.
on 22-09-2021 15:25
Hi GoldenB0y
Thanks for reaching out to us here on the community and thank you to lotharmat for your assistance.
I just want wanted to check in and see if you have been able to split the WiFi bands as suggested?
If so, have you seen any improvements at all?
Let us know 🙂
