David4
  • 10
Why is my broadband speed so slow?
I am getting very slow speeds - download 15.35, upload 20.87 and ping 13. Virgin reckon I should be getting up to 200 mbps but this is nowhere near it. I use an ethernet connection to the hub so why is so slow!!
Also how do I contact Virgin about this as there doesn't seem an obvious way?
Thanks, David
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Why is my broadband speed so slow?
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
David4
  • 10
Hi Mike,
Thanks for the quick reply. I tried the speed test again with my laptop directly connected to the router and it was much quicker so clearly the issue is my ancient PC!
Thanks again,
David
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Is the PC connecting with Wi-Fi or ethernet ?
