Which Broadband speed checker
Rocket4
Hi guys, just had new install and not sure which speed checker to use? On the virgin app we've got the speedo dial type,  for modem mode,  and the other one that shows a guy sat at a pc (Sam knows)  which one should I be using? I've got the 250 package and the dial checker shows me at 57 ish mbps, the other shows 276 at router and me at 57 ish. I'm guessing that's my speed? Apologies for ignorance!
1 REPLY 1
Legend
For a VM Hub 3/4/5 in Router mode we use  :
For M250 seeing 276 Download at the Hub is good, so why are you seeing 57 Download at the PC  ?
Perhaps that is due to use of a 2.4GHz Wi-Fi connection or even some kind of Power line extender.
A direct network cable connection from the Hub to the PC should a faster result
