Robbo30000
Message 1 of 11
When will my speed be updated
Hey guys hope youre all well. I was wondering when my wifi speed will increase as Ive just upgraded from 100 to 350mps. I have all the confirmation emails of it. Cheers
Tags (2)
ro55co
  • 30
  • 9
Message 2 of 11
Re: When will my speed be updated
Hi Robbo. I upgraded from 100 to 350 on Saturday and my speed has actually plummeted !!!! I have messaged a complaint to VM (3 days ago) and am awaiting a reply. I am considering cancelling the upgrade within the 14 day cooling off period if I don't hear anything soon.
Buffer6
  • 11.22K
  • 93
  • 632
Hero
Message 3 of 11
Speed upgrades can take up to 48hrs before they come through
rebooting your Hub can sometimes force them to come through quicker
or on running the broadband test in myvirginmedia a new config might
then come through.
ro55co
  • 30
  • 9
Message 4 of 11
Thanks Buffers for the suggestion. I tried the reboot and also a pin hole reset. Neither worked.
When I agreed to the upgrade I checked my speed at 107.66mbps. It is now averaging 48.80mbps - it makes no logical sense. I hope I get a response to my complaint before my 14 day cooling off period expires.
Robbo - did your speed eventually improve ???
  • 3.2K
  • 251
  • 699
Message 5 of 11
Wired or WiFi speed tests?  Only wired to the Hub is used by VM for troubleshooting.
Also post your logs, power levels and configuration from the Hub for comment here.   A TBB monitor here will also help in diagnostics  www.thinkbroadband.com/ping
ro55co
  • 30
  • 9
Message 6 of 11
Thanks Adduxi. All my tests have been using Ookla and with a cabled connection. Here is the latest test a few minutes ago:
And that's on my spanking new M350 upgrade !!!!
I will have a look at the link you attached. Thanks again.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 11
Hub 3 When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Configuration tab onto here, if you get a yellow warning click the Post button again. Please do not use screen grabs.
ro55co
  • 30
  • 9
Message 8 of 11
Hi Mike. I really appreciate you trying to help.
When I enter the site I selected language and then the only option is a window to log in. There is no option to check router status (or anything else).
I entered the password and got this page:
Welcome
Quick Set-Up Wizards
Configure your Wi-Fi network
Network diagnostic tool
Modify your Guest network
Hub 3.0 status overview
Your Hub 3.0 status
 Wireless(On (2.4 and 5 GHz))
 Internet(Online)
 Telephony(Disabled)
No obvious place to 'check router status' without clicking on one of the tabs which scares the life out of me !!!!!
Anonymous
Not applicable
Message 9 of 11
Advanced settings\Tools\Network status.
ro55co
  • 30
  • 9
Message 10 of 11
This is what I get:
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID606030
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID606029
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBest Effort
Latest speed test gives 39.58mbps !!!!
