@Husk24 wrote:
Would it improve if I invested in a wifi 6 router.?
Do you have WiFi 6 devices?
The 3167Mbps value in your router's specs is based on adding the throughput of the 2.4Ghz (1000Mbps) and 5Ghz (2167Mbps) bands combined.
So if you have a device connected to the 5Ghz band you have upto 2167Mbps, however the device itself must be capable of 4x4 MIMO (Multiple Input Multiple Output):
https://www.duckware.com/tech/wifi-in-the-us.html
Most devices are 2x2 MIMO.
THEN you have to consider the external factors:
- Distance from the Router.
- Interference from objects.
- Interference from other wireless networks.
