allahmcat
  • 12
Message 1 of 23
What does the 100Mbps the hub connected devices mean?
On the Hub 3.0 in the Connected devices, under Speed(Mbps) it indicates that my directly cable connected 1GB led is green) laptop is connected at 100Mbps.
 My package is 200MB - does this mean the connection is limited to 100MB?
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 2 of 23
Re: What does the 100Mbps the hub connected devices mean?
Possibly or it’s a glitch
What cable are you using and what make and model is the Ethernet adaptor?
allahmcat
  • 12
Message 3 of 23
Laptop --> Cat6 ethernet cable --> TP-Link TL-SG108S 8-Port Desktop Gigabit Ethernet Switch --> Cat6 ethernet cable --> Hub 3.0
All LED's on laptop, switch and hub are green (would be yellow if 100M)
One other PC on switch, which also has GB network card.
/Mike
  • 2.87K
  • 214
  • 609
Trouble shooter
Message 4 of 23
Have you actually done a speed test from the laptop?  If so what was the result.
allahmcat
  • 12
Message 5 of 23
Yes, I have done a Speed test. Speeds consistently less than expected.
  • 2.87K
  • 214
  • 609
Trouble shooter
Message 6 of 23
Can't see you pic until it's approved.  If you ever get over 100 then it's running at 1Gig.  Around less than 90mb then it is only connecting at 100mb.
allahmcat
  • 12
Message 7 of 23
Here is the data in text over the last few days:
DateTime Download DateTime Upload
2020-05-01 22:46:29.993 32.6 2020-05-01 22:46:29.993 1.4
2020-05-01 22:49:31.072 21.4 2020-05-01 22:49:31.072 9.58
2020-05-01 23:04:59.921 24.29 2020-05-01 23:04:59.921 8.43
2020-05-02 00:12:25.636 58.42 2020-05-02 00:12:25.636 18.29
2020-05-02 09:27:15.392 57.09 2020-05-02 09:27:15.392 15.91
2020-05-02 09:28:48.414 56.63 2020-05-02 09:28:48.414 20.37
2020-05-02 19:48:44.261 63.07 2020-05-02 19:48:44.261 10.53
2020-05-02 23:37:48.315 57.84 2020-05-02 23:37:48.315 9.68
2020-05-03 00:17:16.408 58.53 2020-05-03 00:17:16.408 19.29
2020-05-03 08:29:26.821 59.25 2020-05-03 08:29:26.821 20.46
2020-05-03 14:51:24.460 58.42 2020-05-03 14:51:24.460 16.54
2020-05-03 17:58:55.868 45.54 2020-05-03 17:58:55.868 15.23
2020-05-03 23:05:47.275 54.92 2020-05-03 23:05:47.275 18.65
2020-05-03 23:55:04.199 62.27 2020-05-03 23:55:04.199 14.23
2020-05-04 06:47:46.564 56.44 2020-05-04 06:47:46.564 18.19
2020-05-04 08:38:45.315 61.54 2020-05-04 08:38:45.315 21.1
2020-05-04 09:02:14.749 60.55 2020-05-04 09:02:14.749 20.56
2020-05-04 09:22:15.123 56.02 2020-05-04 09:22:15.123 17.23
2020-05-04 09:43:10.992 35.47 2020-05-04 09:43:10.992 16.94
2020-05-04 10:17:25.915 60.27 2020-05-04 10:17:25.915 18.58
2020-05-04 10:37:52.718 51.57 2020-05-04 10:37:52.718 16.5
2020-05-04 11:42:06.873 52.82 2020-05-04 11:42:06.873 14.51
2020-05-04 14:12:35.392 19.57 2020-05-04 14:12:35.392 3.17
2020-05-04 15:01:01.714 53.08 2020-05-04 15:01:01.714 17.67
2020-05-04 16:29:15.734 31.15 2020-05-04 16:29:15.734 11.8
2020-05-05 05:08:54.773 55.74 2020-05-05 05:08:54.773 21.35
2020-05-05 08:55:40.947 36.68 2020-05-05 08:55:40.947 16.86
2020-05-05 09:33:10.487 15.82 2020-05-05 09:33:10.487 13.53
2020-05-05 09:58:05.270 14.58 2020-05-05 09:58:05.270 8.91
2020-05-05 14:32:46.749 25.76 2020-05-05 14:32:46.749 10.83
2020-05-05 16:22:12.718 52.26 2020-05-05 16:22:12.718 13.72
2020-05-05 16:33:33.589 12.67 2020-05-05 16:33:33.589 12.79
2020-05-05 23:13:19.644 25.02 2020-05-05 23:13:19.644 15.58
2020-05-05 23:36:56.502 22.25 2020-05-05 23:36:56.502 18.61
2020-05-06 07:02:01.155 57.87 2020-05-06 07:02:01.155 19.89
2020-05-06 07:52:31.220 57.95 2020-05-06 07:52:31.220 17.77
2020-05-06 08:46:37.801 62.2 2020-05-06 08:46:37.801 21.14
2020-05-06 10:08:11.631 54.07 2020-05-06 10:08:11.631 15.99
2020-05-06 10:55:52.707 39.04 2020-05-06 10:55:52.707 13.02
2020-05-06 14:07:22.634 53.35 2020-05-06 14:07:22.634 17.26
2020-05-06 15:47:28.621 49.97 2020-05-06 15:47:28.621 14.51
2020-05-06 16:10:30.450 33.6 2020-05-06 16:10:30.450 9.17
2020-05-06 16:40:27.902 25.58 2020-05-06 16:40:27.902 16
2020-05-06 22:06:49.TV 58.6 2020-05-06 22:06:49.TV 20.14
2020-05-07 07:06:25.226 68.35 2020-05-07 07:06:25.226 20.58
2020-05-07 08:09:25.496 57.98 2020-05-07 08:09:25.496 17.81
2020-05-07 12:07:01.536 32.65 2020-05-07 12:07:01.536 17.32
allahmcat
  • 12
Message 8 of 23
Latency is getting worse. Difficult to type anything in PuTTY window. Characters slow to appear etc.
allahmcat
  • 12
Message 9 of 23
Reposting Latency image (without personal details)
  • 2.87K
  • 214
  • 609
Trouble shooter
Message 10 of 23
That image is a classic case of an overloaded local circuit, i.e. too many users hence the performance is good overnight when most are in bed sleeping 🙂
