Cate2
Settling in
Webex freezing during calls. Connected via WIFI. No other connectivity issues. Speed seems good.
When I join a webex call from my laptop after some time it will freeze and I will end up having to crash it to leave it. Often having to shut down entire laptop to reboot to get back online.
I am WFH since mid March with no prior issues in connectivity during this time. I am using WIFI.
How can I resolve this issue.
Speedtest results showing below:
Thanks a lot!
Kind regards,
Catherine
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Webex freezing during calls. Connected via WIFI. No other connectivity issues. Speed seems good.
The best resolution is to use an ethernet cable connection between laptop and Hub.
