Millsy2910
Webex and Skype cusound drop out
I've recently been having issues on works calls via Webex where the sound and video drops out in the middle of calls. I've also had issues in sending Skype IM's too were they do not send. I've also had issues when using a mobile on wifi call since I have had my broadband fitted.
I've reset my broadband and tested the WIFI and all seems good so unsure what this maybe.
Can someone help please?
James
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Webex and Skype cusound drop out
VM do not, and never have guaranteed Wi-Fi speed or coverage.
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something, somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
If you remove all the internal walls, water, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from an ISP Hub.
Just a few things that can affect Wi-Fi in the average home …
Blockage (visible) …
Mirrors, furniture, fish tanks, people, radiators, walls, flooring / ceilings.
Interference (invisible) …
Cordless phones, baby monitors, microwave ovens, fridges & freezers, TVs, next doors Wi-Fi and Wi-Fi equipment, DAB transmitters, the list is endless.
My VM Hub 3 Wi-Fi went into meltdown when the local authority / police CCTV camera on the lamppost adjacent to my house was used.
Many people have accepted that the VM Wi-Fi is poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
