Hi no faults, VM doing work on the network in our area tomorrow, just had confirmation by text. Testing via the VM site suggests that my hub isn't connecting properly, and even in the same room as it there seem to be blank spots - even when its in line of sight a few feet away.
I have reset the hub several times, and the problem won't go away.
If I turn off the wifi and connect by ethernet cable, the pages still take longer to load than they used to, and sometimes just stall completely with the progress bar less that a quarter of the way across.
It looks like the problem is persistent, and inconsistent, if you will.
This is the speedtest I have just carried out
Virgin Media
82.31.8.74
Then a second: with the same company
Virgin Media
82.31.8.74
and a third with a different tester returned (can't copy/pront it)
Internet speed test 84.2 and 9.87.
Cheers
