  • 144
  • 12
Dialled in
Message 1 of 22
Way less than what I am paying for and also, what are these errors?
I pay for M200 but rarely if ever get those kind of speeds.
Having checked the router status, I am wondering if these errors have anything to do with it.
Can anyone please explain what they are all about and if these are a real problem?
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 22
Re: Way less than what I am paying for and also, what are these errors?
Post back the full network, upstream and downstream logs.
copy and paste them back as images take time to be approved
What speeds do you get wired direct to the hub?
  • 144
  • 12
Dialled in
Message 3 of 22
is that what you mean?
Also, around 10-120 wired direct to hub.
I was also a little miffed as to the "Max Rate" of 54 showing on InSSider. Should that also be 54?
1394000005.1512064 qam6
2258000005.1512032 qam8
3326000005.1512032 qam7
4462000005.1512064 qam5
3ATDMA0000
4ATDMA0000
14110000005.338256 qam33
22190000005.840256 qam11
32270000005.440256 qam12
42350000005.640256 qam13
5243000000640256 qam14
62510000005.540256 qam15
72590000006.338256 qam16
82670000006.440256 qam17
92750000005.940256 qam18
102830000006.540256 qam19
11291000000638256 qam20
12299000000640256 qam21
133070000005.940256 qam22
14315000000640256 qam23
153230000005.538256 qam24
163470000004.640256 qam25
173550000005.640256 qam26
18363000000538256 qam27
19371000000538256 qam28
20379000000638256 qam29
21387000000540256 qam30
223950000005.838256 qam31
23403000000638256 qam32
244190000005.840256 qam34
1Locked38.9161213
2Locked40.3606518
3Locked40.3612476
4Locked40.3605521
5Locked40.3536467
6Locked40.3496497
7Locked38.9440456
8Locked40.3444394
9Locked40.3408423
10Locked40.9338243
11Locked38.9313232
12Locked40.3307159
13Locked40.933289
14Locked40.326393
15Locked38.927292
16Locked40.9298128
17Locked40.3272145
18Locked38.9277172
19Locked38.6309165
20Locked38.9231215
21Locked40.9312183
22Locked38.9197224
23Locked38.9136207
24Locked40.316281
31/05/2020 10:40:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 10:40:38Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:41:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:41:41criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:38:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:38:41criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:35:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:35:41criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:34:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:34:1criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:31:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:31:2criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:27:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:27:2criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:24:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:24:22criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:23:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:23:2criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:21:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 08:21:42criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Bsgvca69834ncxv9873254k;fg87ds
SFID25796
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID22342
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 22
54Mbps is the link speed if your WiFi card.
Your stats are a little all over the place - namely the upstream levels being too high and the pre and post RS counts in the downstream.
When was the hub last rebooted?
  • 144
  • 12
Dialled in
Message 5 of 22
A couple of weeks ago when tech guy had been.
I will reboot now and upload all the details after it's done.
You do mean just a simple reboot and not a reset right as that is a PITA to change all the setting etc
  • 144
  • 12
Dialled in
Message 6 of 22
14110000005.138256 qam33
32270000005.540256 qam12
62510000005.440256 qam15
7259000000640256 qam16
82670000006.140256 qam17
92750000005.540256 qam18
102830000006.340256 qam19
112910000005.640256 qam20
122990000005.840256 qam21
133070000005.840256 qam22
163470000004.540256 qam25
173550000005.540256 qam26
193710000004.840256 qam28
203790000005.840256 qam29
244190000005.640256 qam34
1Locked38.900
2Locked40.350
3Locked40.350
4Locked40.300
5Locked40.960
6Locked40.300
7Locked40.350
8Locked40.940
9Locked40.300
10Locked40.330
11Locked40.350
12Locked40.370
13Locked40.360
14Locked40.340
15Locked38.950
16Locked40.370
17Locked40.350
18Locked38.950
19Locked40.300
20Locked40.300
21Locked40.300
22Locked38.9200
23Locked38.9170
24Locked40.300
1393999645.1512064 qam6
2257999915.1512064 qam8
3325999985.1512064 qam7
4461999885.1512064 qam5
3ATDMA0000
4ATDMA0000
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
834ncxv9873254k;fg87dsfd;kfoA,
  • 20.96K
  • 1.13K
  • 2.7K
Message 7 of 22
Just a reboot to see what the levels look like again and see what the speeds are like.
  • 144
  • 12
Dialled in
Message 8 of 22
SFID25796
Min Traffic Rate0
SFID22342
Min Traffic Rate0
31/05/2020 11:29:3ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.33K
  • 255
  • 513
Message 9 of 22
Hi silentg1971
Thanks for the last post
Have you noticed any improvement since at all?
Gareth_L
  • 14.82K
  • 1.16K
  • 3.46K
Message 10 of 22
@Gareth_L wrote:
Hi silentg1971
Gareth_L
why is nobody picking up on the upstream levels - at 5.1 [51] they are surely out of spec
____________________
Tony
