Jec4508
WIFI issues and contacting Virgin Media
My WIFI is constantly disconnecting and will not reconnect until I have attempted reconnection several times.  I am working from home and finding this incredibly frustrating because I have to lead meetings and present, embarrassing when you are literally thrown off.
I have tried calling Virgin and wait for an age before being cut off via that route too.
I want to leave but you can only do that by contacting them by phone which is not answered.
I understand the issues everyone is faced with e.g. working from home during the pandemic but I really need to get these issues resolved immediately.
Any advice anyone?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: WIFI issues and contacting Virgin Media
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Andrew-G
  • 6.94K
  • 1.21K
  • 3.03K
Depends on what you want to do.  If you want to leave, you can cancel by post (section N of the T&Cs), but wait until the new ISP is connected and working before cancelling VM.  That may be a bit drastic, so if you'll give VM the chance and you want VM to fix the connection, then we (unpaid helpers with time on our hands and a smattering of technical knowledge) will do our best to help.
As a start, connect to the hub's login page at http://192.168.0.1/ but don't login.  See that link "Check router status"?  Click on it.  That'll bring up a window with five tabs.  Select, copy and paste the contents of the three tabs titled Downstream, Upstream, Network log into three replies here.  Make sure they're pasted as text as images and screenshots cause us problems due to poor legibility, delays in moderation and missing info.  Then we can look for signs of trouble and bring that to the attention of the VM forum staff to advise on some next steps.
I'm assuming you've tried restarting the hub, doing a pinhole reset, and making sure the coaxial cable to the hub is plugged in properly with the securing nuts finger tight?
