properpanda
Message 1 of 7
WAN Connection: ISP's DHCP did not function properly.
Broadband is great when it works and like toothache when it doe not.
I am currently paying £67 a month for a 500meg service(or not as in my case). My family with 2 children trying to home-school during lockdown that experience consistently 3 times a day a complete drop of connection.
I thought i would be proactive and bought a great new router (ASUS RT-AC66U) and set the hub 3.0 as a modem. The router is great but the hub 3.0 is still restarting 3 times a day.
Customer Service is non existent!
So I thought I would post a message on here in the vane hope that someone in Virgin land hears me.
My new router says "Feb 5 11:42:34 WAN Connection: ISP's DHCP did not function properly."
My hub3.0 says:
05/02/2021 11:49:47criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:48:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:47:0criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:46:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:44:23criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:43:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:42:15criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:38:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:38:5criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:38:5criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:37:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:37:43criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:37:43criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:37:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:36:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 11:36:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 08:30:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 08:30:18criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 06:58:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 06:56:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
tehwolf
  • 1.62K
  • 263
  • 393
Superfast
Message 2 of 7
Re: WAN Connection: ISP's DHCP did not function properly.
In addition to the log that you've already posted, could you post the tables from the upstream and downstream tabs.. you will probably have to split this over two posts.. may as well repost the log as well - see if there's anything else in there.
you've got a bunch of t3 timeouts and i believe (though I'm very much an amateur with this stuff) that the RCS partial service message indicates that one (or maybe more?) of the channels is dropping out of sync/service.
you've made the right decision in buying your own wifi gear, unfortunately, though, if the underlying connection is bad no 3rd party router is gonna fix it..
it's also worth setting up a BQM and posting the "live link" back here - make sure you choose the "sharing link" which will remove your public ip address from the image..
post up the stats and let's have a look..
  • 15.46K
  • 662
  • 1.51K
Message 3 of 7
try this
https://www.asus.com/support/FAQ/1043591
ravenstar68
  • 18.73K
  • 1.09K
  • 8.06K
Message 4 of 7
I would disregard @legacy1 's suggestion for now.
Looking at the log you are showing multiple RCS Partial Service errors and Loss of Sync signals.  In short, the DHCP message is a red herring.  It's the underlying connection that's at issue.
Please follow @tehwolf 's advice and post your power levels.
The Forum Team will get to the post but it can take a few days to do so.
Tim
properpanda
Message 5 of 7
Thanks for the replies I have had so far.
I did eventually manage to get through to the virgin support team who have tried various things in the last 30 hours some which seem to have worked. I did ask them what they had tried but they said  it was company policy not to give out that sort of information. They said they would monitor the situation and send an engineer if the problem did not rectify itself. the connection has been up for over 20 hours now so fingers crossed.
Thanks again for any advice given it is appreciated. I will post my Downstream & Upstream data if the problem of connection reoccurs.
ravenstar68
  • 18.73K
  • 1.09K
  • 8.06K
Message 6 of 7
@properpanda
I'm glad it seems to be working for you now, but would you humour us and post the stats anyway?
Tim
properpanda
Message 7 of 7
for Ravenstar68
The engineer from VM came around today through the snow.
And...
We worked through the problem of my broadband connection and narrowed it down to ...
DAMP!
Yes folks DAMP. it seems that my connection through the wall had corroded causing a fluctuation in signal strength due to water short circuit.
So look out for this as a possible solution to your own issue. If you have one.
Thanks and good night. End Thread.
14190000007.140256 qam32
22030000006.540256 qam9
32110000006.540256 qam10
42190000006.540256 qam11
52270000006.440256 qam12
62350000006.140256 qam13
72430000005.440256 qam14
82510000004.140256 qam15
92590000005.440256 qam16
102670000006.540256 qam17
112750000006.840256 qam18
122830000007.140256 qam19
132910000007.440256 qam20
142990000007.640256 qam21
153070000007.540256 qam22
163150000007.540256 qam23
173230000007.640256 qam24
183310000007.940256 qam25
19371000000740256 qam26
203790000006.440256 qam27
213870000006.540256 qam28
223950000006.640256 qam29
23403000000740256 qam30
24411000000740256 qam31
1Locked40.9157111303
2Locked40.36271114980
3Locked40.35057229016
4Locked40.3235197730
5Locked40.354928949
6Locked40.3147609463
7Locked40.354449718
8Locked40.324328379
9Locked40.323787850
10Locked40.323326689
11Locked40.321176314
12Locked40.320957215
13Locked40.323187823
14Locked40.336527479
15Locked40.320847171
16Locked40.919137696
17Locked40.919637287
18Locked40.916336780
19Locked40.314626089
20Locked40.916946013
21Locked40.320184738
22Locked40.315955706
23Locked40.314625593
24Locked40.911862195
15370025343512064 qam2
24620000042.8512064 qam3
33940000042.5512064 qam4
46030023943512064 qam1
3ATDMA0000
4ATDMA0000
Tags (1)
