mjccam
  • 5
Message 1 of 5
Volt speed increase - still wating
Hi all,
My volt benefit with o2 was applied pretty quickly - data doubled from 30gb to 60gb, but the Virgin Media speed increase for my broadband hasn't happened yet. It's been more than 3 weeks now and no sign of it. I phoned up a few days ago but the agent seemed to think it was a fault and no amount of explaining could bring her round to understand that it was a volt speed boost i was missing. It was hard work.
I've searched online on my account and there's nothing obvious to find out what's going on, is there anyone on here that is available to help?
Tags (3)
  • 6.81K
  • 592
  • 1.78K
Message 2 of 5
Re: Volt speed increase - still wating
It normally takes 14 days to activate, so 3 weeks should be ample.
Check your account names etc. are EXACTLY the same on O2 and VM, as this can cause the VOLT upgrade to fail.
Also check the conf settings on the Hub. It will show what speed has been provisioned.
It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate.
You could also try a factory reset to force down the latest config file to your Hub.
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
If you wait here a day or two a VM Mod will pick this up.
Travis_M
  • 4.6K
  • 169
  • 336
Message 3 of 5
Hi @mjccam
Thanks for posting on our community forum!
Sorry to hear about your issue, are you able to advise if you've checked on the above? Has the speed still not been increased?
Please do update us
Travis_M
mjccam
  • 5
Message 4 of 5
I actually phoned up again and went through to retentions who after over an hour on the phone managed to sort it out. No agents seem to know the full details on this deal on doubling speed so are at a loss as what to do. After the agent spoke to their manager, i've was upgraded instantly, but they were only able to do it after renewing my contract (i've only had VM for a month) so i have a new contract start date and end date - albeit only a month extra and i've now got the increased speed for the same price as before.
A bit of a round about way of doing things but apparently it was the only way they could get it to work. For something that should have been automated, it's been a bit of a farce!
David_Bn
  • 9.41K
  • 394
  • 718
Message 5 of 5
Thanks for the update @mjccam, and we're sorry to hear this was a difficult process
We're pleased though of course this has now been resolved for you
Do feel free come back to our Community Forums if you have any further issues with the services
Kindest regards,
David_Bn
