Hi All,
Have no words any more, only emotions.
Have some strange issue with the Virgin network...
In Jan changed my broadband to that magnificent "VOLT" package. So hoped to get all advantages of almost good broadband speed, but have got huge headache.
Tried to get some help from the support... Support is very good, but my opinion is that you could easily fire all those people and just add few options to your phone line with the messages like "Reboot your HUB" or "Do hard reset of it". So not helpful at all.
Once I have got technician to come, that lovely person came did some tastings as a conclusion he said that everything should be OK. Same evening I did call to very helpful support again as issue didn't disappear.
In simple words could say that Virgin tries to lie about how good is their speed (hope this message won't disappear after those words). Literally when you do your speed check mostly it shows speed which we should get, but if you would try to hold speed check a bit longer that 3-7 seconds you will see strange situation speed goes down, won't even say goes, it falls down in my situation. Could say that from my max real speed of around 70 Mbps (advert was 350) falls down to ZERO. Holds that minimum for 2-3 seconds and then pops up back to almost 70+. Probably you would ask how often it happens? Answer is always, every 2-5 minutes I could see that.
Below you will see "Broadband Quality Monitor" picture from www.thinkbroadband.com/, if that won't be blocked :).
In case it was blocked fill free to use this link to see.
Thanks for reading this long article.
Below I have added some technical info:
1 | 723000000 | 6 | 40 | 256 qam | 40 |
2 | 539000000 | 5 | 40 | 256 qam | 17 |
3 | 547000000 | 5.1 | 40 | 256 qam | 18 |
4 | 555000000 | 5.1 | 40 | 256 qam | 19 |
5 | 563000000 | 5.4 | 40 | 256 qam | 20 |
6 | 571000000 | 5.4 | 40 | 256 qam | 21 |
7 | 579000000 | 5.4 | 40 | 256 qam | 22 |
8 | 587000000 | 5.5 | 40 | 256 qam | 23 |
9 | 595000000 | 5.5 | 40 | 256 qam | 24 |
10 | 603000000 | 5.5 | 40 | 256 qam | 25 |
11 | 611000000 | 5.8 | 40 | 256 qam | 26 |
12 | 619000000 | 5.5 | 40 | 256 qam | 27 |
13 | 627000000 | 5.6 | 40 | 256 qam | 28 |
14 | 635000000 | 5.4 | 40 | 256 qam | 29 |
15 | 643000000 | 5.8 | 40 | 256 qam | 30 |
16 | 651000000 | 5.5 | 40 | 256 qam | 31 |
17 | 659000000 | 5.9 | 40 | 256 qam | 32 |
18 | 667000000 | 5.6 | 40 | 256 qam | 33 |
19 | 675000000 | 5.6 | 40 | 256 qam | 34 |
20 | 683000000 | 5.5 | 40 | 256 qam | 35 |
21 | 691000000 | 5.5 | 40 | 256 qam | 36 |
22 | 699000000 | 5.5 | 40 | 256 qam | 37 |
23 | 707000000 | 5.9 | 40 | 256 qam | 38 |
24 | 715000000 | 5.8 | 40 | 256 qam | 39 |
1 | Locked | 40.3 | 103 | 0 |
2 | Locked | 40.3 | 110 | 0 |
3 | Locked | 40.3 | 104 | 0 |
4 | Locked | 40.3 | 94 | 0 |
5 | Locked | 40.3 | 89 | 0 |
6 | Locked | 40.3 | 69 | 0 |
7 | Locked | 40.3 | 102 | 0 |
8 | Locked | 40.9 | 87 | 0 |
9 | Locked | 40.3 | 71 | 0 |
10 | Locked | 40.3 | 67 | 0 |
11 | Locked | 40.9 | 99 | 0 |
12 | Locked | 40.3 | 85 | 0 |
13 | Locked | 40.3 | 67 | 0 |
14 | Locked | 40.3 | 110 | 0 |
15 | Locked | 40.3 | 78 | 0 |
16 | Locked | 40.3 | 95 | 0 |
17 | Locked | 40.3 | 65 | 0 |
18 | Locked | 40.3 | 83 | 0 |
19 | Locked | 40.9 | 67 | 0 |
20 | Locked | 40.3 | 97 | 0 |
21 | Locked | 40.3 | 103 | 0 |
22 | Locked | 40.9 | 91 | 0 |
23 | Locked | 40.3 | 94 | 0 |
24 | Locked | 40.3 | 82 | 0 |
1 | 25800000 | 40.8 | 5120 | 64 qam | 6 |
2 | 32600000 | 40.8 | 5120 | 64 qam | 5 |
3 | 39400000 | 42.3 | 5120 | 64 qam | 4 |
4 | 46200000 | 42.3 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 7 | 0 |
3 | ATDMA | 0 | 0 | 5 | 0 |
4 | ATDMA | 0 | 0 | 5 | 0 |
