  • 15
Gina1980
Message 1 of 7
Vivid 100 but my upload and download speed is 2.35Mbps
I am supposedly on Vivid 100 and supposedly had a "Speed Boost" and yet ever since I got the letter to tell me about this "boost," the internet speed has been atrocious.  I've just run Speedtest and my upload is 2.34 and download is 2.36. What is going on?
Anyone else?
How do I get it fixed?
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 2 of 7
Re: Vivid 100 but my upload and download speed is 2.35Mbps
how did you run the speedtest? via wifi or ethernet?
  • 15
Gina1980
Message 3 of 7
Via wifi.
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 4 of 7
speedtests should only be done via ethernet.
a wifi speedtest is totally unreliable and cannot be used to test your connection speed.
  • 15
Gina1980
Message 5 of 7
That's a shame as my laptop doesn't have an ethernet port.
Interestingly, wifi speed tests in the past have indicated high speeds in the 70s-80s.  For the last two weeks websites are slow to respond and it is taking a really long time to upload and download documents.  So although a wifi speed test may not be reliable, it is interesting then that this experience has correlated with a wifi speed test of 1-2.5Mbps.
It seems a lot of other people are also affected on Twitter. They have been using wired speed tests.
  • 3.65K
  • 201
  • 610
chenks
Community elder
Message 6 of 7
it may be you have a local WIFI issue rather than a connection speed issue.
unless you can test via ethernet you won't be able to confirm.
you also can't base what issues others have as you are not able to actually test your physical connection.
  • 10.63K
  • 1.09K
  • 1.69K
Message 7 of 7
Neither does my Macbook but I still connect it by ethernet cable for testing purposes.  Get to eBay and get a USB3/USBc/Thunderbolt/Lightning/or whatever you have -> to ethernet - adapter - usually less than a tenner. Also, 20m of Cat5e cable is a <£5.
