RonD1
  • 15
Message 1 of 12
Virgin wifi defaulting to our previous Sky wifi
We switched from Sky to Virgin Media about a month ago and all the sky equipment ahs been disconnected and is in a box in the loft.  However, whenever the VM wifi cuts out or the Hub has to be rebooted, the wifi on our devices (iPhone, iPad etc) reverts to the Sky wifi that we used to have, or at least that is what it shows up as.  The download speed shown is intermediate between the Sky that we had (~ 14 Mbits) and the Virgin (108 Mbits) and the upload speed is also in between (Sky 1.0 Mbits, Virgin 10 Mbits).
The second issue we have is that our Apple devices are saying that the Virgin Wifi has weak security (WPA2 (TKIP) and that the router should be configured to use (WPA2 (AES) or WPA3.  Should we be concerned about this and if so, is it possible to change it in our router settings, and how?
Many thanks.
nodrogd
  • 16.8K
  • 1.97K
  • 4.08K
Message 2 of 12
Re: Virgin wifi defaulting to our previous Sky wifi
As far as the WiFi security issue see this:
https://community.virginmedia.com/t5/Security-matters/iOS-14-Weak-Security/td-p/4478034
Most equipment has the option to "forget" an unwanted connection. Have you tried using this.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
RonD1
  • 15
Message 3 of 12
Many thanks for that and most helpful.  I have changed the security settings and the 'Weak Security' warning has gone away.
Re the Sky wifi, we have clicked on Forget many times but it persists and defaults back in any time the Virgin wifi is down.
Anonymous
Not applicable
Message 4 of 12
impossible. If you have unplugged the old router there is no connection for it to default back to.
  • 23.93K
  • 2.53K
  • 4.34K
Message 5 of 12
Are you sure that's your old Sky SSID that you are seeing and not your neighbours?
If its the same SSID name - is there any equipment plugged in from the Sky days? Boosters, Home Hubs etc?
Anonymous
Not applicable
Message 6 of 12
Maybe a rogue wifi booster somewhere you haven't reconfigured?
RonD1
  • 15
Message 7 of 12
Hi John
Yes, I know it is our old Sky wifi name because it I named it uniquely when I split the % and 2.4 GHz signals.
It has been suggested to me that although it should not happen, one of our devices with the Sky wifi details managed to write it onto the Virgin Hub, so it shows up as Sky although it is actually the VM wifi.  But why the speed is slower than the actual VM one is a mystery.
Ron
Anonymous
Not applicable
Message 8 of 12
@RonD1 wrote:
Hi John
Ron
Absolute rubbish!
RonD1
  • 15
Message 9 of 12
Any suggestions as to what is actually going on then please?
Anonymous
Not applicable
Message 10 of 12
I asked earlier about other devices like WiFi boosters?
