VM do not guarantee wifi speeds, nor does the Residential service have any SLA's.
However what Hub are you using? Post your power levels and network log from the Hub. Setup a BQM here to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
In the meantime you can try the following;
Try a 60 second factory pinhole reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
After this split the wifi SSID and disable "Smart Optimisation". You can then manually set the band and channel for each wifi device.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
