BrianY
  • 701
  • 23
  • 107
Rising star
Message 1 of 17
Virgin network problem area 22 LS13
Varying download speeds on 200Mb, dropping down to 110Mbdownload but still 21Mb upload.
Checking modem stats getting very noisy and post errors noted.
Upstream dropping to 1 channel on 64qam which after a reboot increases to 2channels on 64qam, remainder on 32qam.
11/07/2020 22:42:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2020 05:47:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2020 05:47:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:25:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:57:24criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:56:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:55:31criticalDHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:46:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:46:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:46:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:46:16criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:46:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:45:56criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:45:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:45:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:44:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:44:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 03:44:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
DJ_Shadow1966
  • 6.87K
  • 1.31K
  • 1.9K
Message 2 of 17
Re: Virgin network problem area 22 LS13
Hello
The logs are only part of what the forum needs to diagnose the problem can you also post your downstream and upstream  stats.
Regards Mike
BrianY
  • 701
  • 23
  • 107
Rising star
Message 3 of 17
1298750000238256 qam21
21387500001.538256 qam1
31467500001.538256 qam2
41547500001.738256 qam3
51627500001.738256 qam4
6170750000238256 qam5
71787500001.938256 qam6
8186750000238256 qam7
9194750000238256 qam8
10202750000238256 qam9
11210750000238256 qam10
12218750000238256 qam11
13226750000238256 qam12
142347500001.938256 qam13
152427500001.738256 qam14
162507500001.538256 qam15
172587500001.738256 qam16
182667500001.738256 qam17
192747500001.738256 qam18
20282750000240256 qam19
212907500001.738256 qam20
223067500002.238256 qam22
233147500002.438256 qam23
243227500002.740256 qam24
1Locked38.940
2Locked38.650
3Locked38.950
4Locked38.960
5Locked38.600
6Locked38.950
7Locked38.660
8Locked38.9190
9Locked38.6180
10Locked38.940
11Locked38.960
12Locked38.940
13Locked38.950
14Locked38.950
15Locked38.950
16Locked38.600
17Locked38.950
18Locked38.640
19Locked38.950
20Locked40.340
21Locked38.950
22Locked38.970
23Locked38.950
24Locked40.360
BrianY
  • 701
  • 23
  • 107
Rising star
Message 4 of 17
1 32599861 4.825 5120 32 qam 3
2 25800000 4.825 5120 32 qam 4
3 39400000 4.825 5120 64 qam 2
4 46200000 4.825 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Tested last half hour!
DJ_Shadow1966
  • 6.87K
  • 1.31K
  • 1.9K
Message 5 of 17
Hello
Yeah there is certainly something going if you hang around a VM forum staff member will have a look at the backend to see if there is anything causing this, this take a few days.
Regards Mike
BrianY
  • 701
  • 23
  • 107
Rising star
Message 6 of 17
As an added pointer, modem has bee showing 32qam/ plenty of post RS errors during last 3/4 weeks, having to reboot as required to correct the errors.
Spotted a network guy working on the main box at the end of the street which brought up the 32qam to 64 qam, but still not stable on 64qam.
BrianY
  • 701
  • 23
  • 107
Rising star
Message 7 of 17
Last update at 22.00hrs which had been checked @20.00hrs as prev post:
1 32600000 4.825 5120 32 qam 3
3 39400000 4.825 5120 32 qam 2
Download @140Mbps and upload 21Mbps.
Zoie_P
  • 2.53K
  • 123
  • 203
Message 8 of 17
Hi BrianY,
Thank you for your post, I have done some remote checks and you are currently affected by an SNR outage the reference is F008215676 and the estimated fix date is the 17th July.
Zoie
BrianY
  • 701
  • 23
  • 107
Rising star
Message 9 of 17
Thanks for that Zoie_P
BrianY
  • 701
  • 23
  • 107
Rising star
Message 10 of 17
Appears repairs completed!
No post rs errors on download, all upload channels 64qam and remain so 36hrs in.
