28-06-2022 10:44 - edited 28-06-2022 10:54
I have been a Virgin Media customer since late march and over the last 2 weeks (ever since we had some maintenance done in the area by Virgin) internet has been unstable when downloading large files. I am using modem mode but tried router mode and the issue persists.
Here is my BQM graph - https://www.thinkbroadband.com/broadband/monitoring/quality/share/20fec4ae8ea479b397fce22246a50bc8c7...
I think this is an issue of congestion but I never had the internet choke due to a heavy download before. (Was with TalkTalk with 70mbps)
Here are the stats for Hub 4 (I am on the M350 plan):
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 0 |
3.0 Downstream channels
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
25 | 331000000 | 1.9 | 38.6 | QAM256 | 25 |
18 | 275000000 | 2.2 | 38.6 | QAM256 | 18 |
19 | 283000000 | 3.1 | 39 | QAM256 | 19 |
20 | 291000000 | 3 | 39 | QAM256 | 20 |
21 | 299000000 | 2.5 | 38.6 | QAM256 | 21 |
22 | 307000000 | 2.3 | 38.6 | QAM256 | 22 |
23 | 315000000 | 1.9 | 39 | QAM256 | 23 |
24 | 323000000 | 1.4 | 39 | QAM256 | 24 |
26 | 339000000 | 1.9 | 38.6 | QAM256 | 26 |
27 | 347000000 | 1.2 | 39 | QAM256 | 27 |
28 | 355000000 | 1.9 | 39 | QAM256 | 28 |
29 | 363000000 | 2.5 | 39 | QAM256 | 29 |
30 | 371000000 | 1.9 | 38.6 | QAM256 | 30 |
31 | 379000000 | 1.3 | 38.6 | QAM256 | 31 |
32 | 387000000 | 1.8 | 39 | QAM256 | 32 |
33 | 395000000 | 0.9 | 38.6 | QAM256 | 33 |
34 | 403000000 | 1 | 38.6 | QAM256 | 34 |
35 | 411000000 | 1.4 | 39 | QAM256 | 35 |
36 | 419000000 | 1.3 | 38.6 | QAM256 | 36 |
37 | 427000000 | 0.8 | 39 | QAM256 | 37 |
38 | 435000000 | 1.9 | 39 | QAM256 | 38 |
39 | 443000000 | 1.8 | 39 | QAM256 | 39 |
40 | 451000000 | 1 | 38.6 | QAM256 | 40 |
41 | 459000000 | 0.7 | 39 | QAM256 | 41 |
42 | 467000000 | 1.2 | 39 | QAM256 | 42 |
43 | 475000000 | 0.5 | 39 | QAM256 | 43 |
44 | 483000000 | 0.8 | 38.6 | QAM256 | 44 |
45 | 491000000 | 1.4 | 39 | QAM256 | 45 |
46 | 499000000 | 1.5 | 39 | QAM256 | 46 |
47 | 507000000 | 1.2 | 39 | QAM256 | 47 |
48 | 515000000 | 1.7 | 38.6 | QAM256 | 48 |
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
25 | Locked | 38.605377 | 0 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.605377 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.605377 | 0 | 0 |
34 | Locked | 38.605377 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.605377 | 0 | 0 |
37 | Locked | 38.983261 | 0 | 0 |
38 | Locked | 38.983261 | 0 | 0 |
39 | Locked | 38.983261 | 0 | 0 |
40 | Locked | 38.605377 | 0 | 0 |
41 | Locked | 38.983261 | 0 | 0 |
42 | Locked | 38.983261 | 0 | 0 |
43 | Locked | 38.983261 | 0 | 0 |
44 | Locked | 38.605377 | 0 | 0 |
45 | Locked | 38.983261 | 0 | 0 |
46 | Locked | 38.983261 | 0 | 0 |
47 | Locked | 38.983261 | 0 | 0 |
48 | Locked | 38.605377 | 0 | 0 |
3.1 Downstream channels
Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
159 | Locked | 40 | -5.1 | 2695714261 | 0 |
3.0 Upstream channels
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 25800000 | 38.5 | 5120 KSym/sec | 64QAM | 6 |
2 | 32600000 | 38.8 | 5120 KSym/sec | 64QAM | 5 |
3 | 39400000 | 39.3 | 5120 KSym/sec | 64QAM | 4 |
4 | 46200000 | 39.8 | 5120 KSym/sec | 64QAM | 3 |
5 | 53700000 | 40.3 | 5120 KSym/sec | 64QAM | 2 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 7 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
on 28-06-2022 17:04
on 28-06-2022 22:25
Quite a lot of T3 timeouts. BQM suggests high evening latency and packet loss.
Check for local issues on 0800 561 0061 and ensure that all cables and connections are tight and secure and not kinked or damaged.
Lastly try a 30 second pinhole reset of the hub with no ethernet connection.
on 29-06-2022 11:57
I have called the number and it has reported that there are NO issues in my area. I have done the pinhole reset and there is still significant evening congestion. Significant latency spikes in games and sporadic speeds. Never had this on TalkTalk. No matter the bandwidth the experience was consistent.
Please see the updated BQM graph for yesterday (28th June 2022) - https://www.thinkbroadband.com/broadband/monitoring/quality/share/080b33412b7accc5c16c94d0da2db4b798...
How likely is it that an engineer can fix this? Would proving my area reference help to identify if my area is suffering from congestion. All this started after the maintenance which was done on the 9th/10th of June 2022.
I am paying a lot for Virgin, surely there should not be any congestion and for Virgin to have the capacity to deal with capacity.
on 29-06-2022 17:38
on 29-06-2022 23:05
How would I be able to arrange for a tech to come and take a look?
on 01-07-2022 22:12
Can someone from the Virgin Media Forum team please take a look at why my line is unstable during peak times? Tonight the internet is unusable regular fluctuations in the ping, which cause webpages and sites to load slower. The number of T3 timeouts has increased into double digits.
2 | US_TYPE_STDMA | 0 | 0 | 11 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 5 | 0 |
on 04-07-2022 11:22
Good Morning @fjama13, thanks for coming back to us.
I've been able to look into the connection on our side and I don't see any issues with the equipment, or any area faults that may be effecting you.
Can you please advise me how the service has performed over the weekend?
Have you possibly set up a BQM to keep tabs on the connection during the course of the day?
Kindest regards,
David_Bn
on 04-07-2022 18:11
I have setup BQM when I had my virgin media installed on the 19th of March
Please see the BQM graph for the 3rd of July but every day since the 9th of June it's been like this. Significant ping spikes during peak times
BQM Graph 3rd July
Live BQM
on 06-07-2022 18:58
Hi fjama13,
Thanks for coming back to us, your BQM could be looking better. After investigating a bit further on this end, we can send that a lot of your signal levels are out of spec which will require an engineer's visit to resolve.
I'm going to pop you over a PM now so I can look into this for you. Please look out for my message at the envelope.
