Ruchir189
  • 14
Message 1 of 15
Virgin Media Broadband Speed is very slow
Hi Team,
I am facing very slow speed for the last around more than 2 week. Whenever I do the speed test it shows me 10-12 Mbps on the line of 108 Mbps.
I don't understand why the speed is not smooth and every time need to chase it to get it corrected.
I have already tried reset and restarting of HUB but no help.
Can you check the line issue please get it sorted?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 15
Re: Virgin Media Broadband Speed is very slow
How are you testing the speed, Wi-Fi or ethernet cable connected device ?
Ruchir189
  • 14
Message 3 of 15
Thanks Mike for your prompt response..
There is no much difference in speed either connected via Wifi or ethernet cable. I have just check the same laptop using Ethernet Cable and the download speed is 11.5 Mbps and Upload is 7.02 Mbps.
On Wifi, the current download speed is less than 10.17 Mbps and 8.74 Mbps upload speed.
Currently I am using 2 laptops and 2 mobiles + 1 Tab on my home network.
Hope the above information will be useful to investigate the issue.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 15
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Ruchir189
  • 14
Message 5 of 15
Dear Mike,
Please find all the requested details below for your investigation.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/846360aef9a10833c368a7a45383f11e86...
Hub 3.0 (DO NOT LOG IN) - Router Status
Cable Modem Status Item Status Comments
202750000
Locked
Ranged Upstream Channel (Hz)
39399897
Locked
Provisioning State
Online
12027500004.540256 qam9
22107500004.540256 qam10
32187500004.540256 qam11
42267500004.440256 qam12
52347500004.540256 qam13
62427500004.540256 qam14
72507500004.340256 qam15
82587500004.540256 qam16
92667500004.340256 qam17
102747500003.940256 qam18
112827500003.940256 qam19
122907500004.140256 qam20
13298750000440256 qam21
143067500003.740256 qam22
153147500003.940256 qam23
16322750000440256 qam24
17330750000440256 qam25
18370750000440256 qam26
193787500004.540256 qam27
203867500004.540256 qam28
213947500004.640256 qam29
22402750000540256 qam30
234107500005.340256 qam31
24418750000540256 qam32
Ruchir189
  • 14
Message 6 of 15
1Locked40.9540
2Locked40.3250
3Locked40.3130
4Locked40.3150
5Locked40.3190
6Locked40.3130
7Locked40.3140
8Locked40.9190
9Locked40.3160
10Locked40.3160
11Locked40.9220
12Locked40.3180
13Locked40.9160
14Locked40.9180
15Locked40.3160
16Locked40.3270
17Locked40.3320
18Locked40.9280
19Locked40.9160
20Locked40.9280
21Locked40.9170
22Locked40.9160
23Locked40.3190
24Locked40.3170
Ruchir189
  • 14
Message 7 of 15
1393998974.25512064 qam2
2462000204.275512064 qam1
3258000004.2512032 qam4
4326000004.25512064 qam3
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID335044
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID335043
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling Type
Best Effort
05/10/2020 12:23:2noticeLAN login Success; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 22:02:49ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 21:51:32ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35criticalNo Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:45:20Warning!Lost MDD Timeout; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:45:16Warning!RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:45:16criticalSYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:43Warning!Lost MDD Timeout; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:38Warning!RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:38criticalSYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:37Warning!RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:37criticalSYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 10:44:36Warning!RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 02:36:33criticalNo Ranging Response received - T3 time-out; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 11:58:15Warning!RCS Partial Service; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 11:58:15criticalSYNC Timing Synchronization failure - Loss of Sync; CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Ruchir189
  • 14
Message 8 of 15
Dear Mike,
Good Afternoon!
I have shared the requested logs yesterday. Speed is still very slow. Have you identified any issues?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 15
Everything looks OK bar the Upstream Channels.
You have one Upstream Channel that is on the wrong modulation, all 4 channels should be at 64 QAM.
Can you perform a reboot using this exact method to see if the Hub can renegotiate a better connection.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check your connection again.
Ruchir189
  • 14
Message 10 of 15
Dear Mark,
Thanks for your suggestion and I have tried the same but speed is still not even better. Please see the logs just captured and help to resolve this issue. I could see that one of channel highlighted below still have issues.
202750000
Locked
39399916
Locked
Provisioning State
Online
1202750000540256 qam9
2210750000540256 qam10
32187500004.940256 qam11
42267500004.940256 qam12
52347500005.140256 qam13
62427500005.140256 qam14
7250750000540256 qam15
8258750000540256 qam16
9266750000540256 qam17
102747500004.540256 qam18
112827500004.540256 qam19
122907500004.940256 qam20
132987500004.940256 qam21
143067500004.440256 qam22
153147500004.540256 qam23
163227500004.840256 qam24
173307500004.640256 qam25
183707500004.640256 qam26
193787500005.140256 qam27
203867500005.140256 qam28
213947500005.440256 qam29
224027500005.540256 qam30
234107500005.940256 qam31
244187500005.640256 qam32
1Locked40.9380
2Locked40.9450
3Locked40.9330
4Locked40.9310
5Locked40.9430
6Locked40.9330
7Locked40.9170
8Locked40.3290
9Locked40.3240
10Locked40.9460
11Locked40.9540
12Locked40.9300
13Locked40.9360
14Locked40.3710
15Locked40.3660
16Locked40.9610
17Locked40.9770
18Locked40.9480
19Locked40.3330
20Locked40.3234226
21Locked40.9320
22Locked40.9480
23Locked40.35271
24Locked40.9340
1393999164.225512064 qam2
2462002074.25512064 qam1
3258000854.196512016 qam4
4326000684.25512064 qam3
3ATDMA0000
4ATDMA0000
