on 25-10-2023 12:35
Hi!
So, I am with Virgin Media on their M500 Package, but we're having frequent disconnections & lag spikes.
(I have troubleshooted, moved the router all of that. / wired connection)
The engineer was sent around, he provided us a new cable & Hub Router, but that did not seem to fix the issues.
I contacted Virgin Media again & they insist that my connection is working completely fine, and will no longer respond about the Lag Spikes or the frequent disconnections when the Router would restart and go green.
I have my logs from the Router Status page, can somebody check these out for me. I've included, downstream, upstream and network log.
If I cannot get this sorted, I will leave anyways.
Thank you here are the logs.
1 | Locked | 38.6 | 107 | 0 |
2 | Locked | 37.6 | 615 | 0 |
3 | Locked | 37.3 | 1022 | 0 |
4 | Locked | 36.6 | 1521 | 27 |
5 | Locked | 35.7 | 2857 | 13 |
6 | Locked | 37.6 | 1988 | 0 |
7 | Locked | 37.6 | 2834 | 56 |
8 | Locked | 37.6 | 530 | 0 |
9 | Locked | 38.6 | 361 | 0 |
10 | Locked | 37.6 | 767 | 0 |
11 | Locked | 37.6 | 1736 | 0 |
12 | Locked | 37.6 | 534 | 0 |
13 | Locked | 37.6 | 346 | 0 |
14 | Locked | 37.6 | 388 | 0 |
15 | Locked | 38.9 | 650 | 0 |
16 | Locked | 37.6 | 908 | 0 |
17 | Locked | 37.6 | 809 | 0 |
18 | Locked | 37.6 | 138 | 0 |
19 | Locked | 37.6 | 110 | 0 |
20 | Locked | 37.6 | 108 | 0 |
21 | Locked | 37.3 | 583 | 0 |
22 | Locked | 38.6 | 564 | 0 |
23 | Locked | 37.6 | 131 | 76 |
24 | Locked | 37.6 | 158 | 0 |
1 | 43100000 | 46.5 | 5120 | 64 qam | 2 |
2 | 23600000 | 45 | 5120 | 32 qam | 5 |
3 | 30100000 | 45.5 | 5120 | 32 qam | 4 |
4 | 36600000 | 45.5 | 5120 | 32 qam | 3 |
5 | 49600000 | 47.3 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 4 | 0 |
2 | ATDMA | 0 | 0 | 0 | 37 |
3 | ATDMA | 0 | 0 | 3 | 12 |
4 | ATDMA | 0 | 0 | 1 | 6 |
5 | ATDMA | 0 | 0 | 2 | 0 |
25/10/2023 12:26:54 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2023 10:31:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2023 10:18:25 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2023 10:15:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2023 10:15:55 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:32:3 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:31:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:31:36 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:30:33 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:30:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:30:16 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:29:3 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:28:47 | notice | Received REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:28:33 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:28:3 | Warning! | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:28:3 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:27:44 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:26:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:26:35 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2023 23:25:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 25-10-2023 12:37
Here is one missing part of the Downstream Bonded Channel
1 | 338750000 | 1 | 38 | 256 qam | 26 |
2 | 202750000 | 1.7 | 37 | 256 qam | 9 |
3 | 210750000 | 1.4 | 37 | 256 qam | 10 |
4 | 218750000 | 1.5 | 36 | 256 qam | 11 |
5 | 226750000 | 1.2 | 35 | 256 qam | 12 |
6 | 234750000 | 1.2 | 37 | 256 qam | 13 |
7 | 242750000 | 0.7 | 37 | 256 qam | 14 |
8 | 250750000 | 0.7 | 37 | 256 qam | 15 |
9 | 258750000 | 0.4 | 38 | 256 qam | 16 |
10 | 266750000 | -0.7 | 37 | 256 qam | 17 |
11 | 274750000 | -0.2 | 37 | 256 qam | 18 |
12 | 282750000 | 0.7 | 37 | 256 qam | 19 |
13 | 290750000 | 0.7 | 37 | 256 qam | 20 |
14 | 298750000 | 0.7 | 37 | 256 qam | 21 |
15 | 306750000 | 0.9 | 38 | 256 qam | 22 |
16 | 314750000 | 0.9 | 37 | 256 qam | 23 |
17 | 322750000 | 0.7 | 37 | 256 qam | 24 |
18 | 330750000 | 1 | 37 | 256 qam | 25 |
19 | 346750000 | 0.7 | 37 | 256 qam | 27 |
20 | 354750000 | 0.7 | 37 | 256 qam | 28 |
21 | 362750000 | 1 | 37 | 256 qam | 29 |
22 | 370750000 | 1 | 38 | 256 qam | 30 |
23 | 378750000 | 1 | 37 | 256 qam | 31 |
24 | 386750000 | 0.4 | 37 | 256 qam | 32 |
on 26-10-2023 15:28
Stats not great - Up qam's dropping to 32 is always a bad sign - as are postRS errors and T3/4 timeouts.
So can you do this to start from a clean sheet..
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Also check the Upstream QAM’s are now at 64 - if they are still dropping (to 32/16) then see message 3 here…
on 28-10-2023 16:32
Hi frankee1, thanks for the message. I can see that Lee has sent you a private message, can you respond to this at your earliest convivence? ^Chris
