odyssey96
Message 1 of 8
Virgin Hub4 /1Gb - ~290Mb/s using WiFi 6 adapters
Just upgraded to 1Gb and getting ~950MB over ehternet.
But only ~290MB on two Dell XPS laptops (13inch/17 inch) which both have Wifi 6 adapters, and this is about 1m away from the hub with a clear line of sight?!  This is even me selecting a 5Ghz channel which is uncongested using the Killer wifi snoop utility
Can anyone give me any pointers?
Anonymous
Not applicable
Message 2 of 8
Re: Virgin Hub4 /1Gb - ~290Mb/s using WiFi 6 adapters
What's the channel width set to on the 5Ghz channel?
Keep in mind that the HUB 4 is ac 4×4 MIMO (Which is 1.3Gbps, read world max around 650Mbps), NOT Wifi 6.
Access the HUB 4 and check the 'Connected devices' section for the 'Speed (Mbps)' column value next to each device.
odyssey96
Message 3 of 8
Channel 100 atm - don't tell me off 😄
Even though I just got a 321.7 Mbps download speed from google speed test, devices tab shows just 6Mbps and remains that way when clicking refresh?!!  Doesn't sound right...
Anonymous
Not applicable
Message 4 of 8
No the channel width 40/80/160Mhz? (Not even sure if the HUB 4 has 160Mhz to be honest).
odyssey96
Message 5 of 8
Oh sorry, it's 20/40/80 - there's no 160 option which makes sense not being wifi 6 which i incorrectly assumed would be the case
Anonymous
Not applicable
Message 6 of 8
You could try forcing the HUB to 40/80 or 80 however it could affect wifi devices not capable of that configuration.
odyssey96
Message 7 of 8
Can only force to 20 or 20/40, not 'upwards' unfortunately
Anonymous
Not applicable
Message 8 of 8
Not much you can do then really, other than use modem mode and buy a decent router!
