1 210000000 7.7 41 QAM 256 10
2 138000000 6.7 41 QAM 256 1
3 146000000 6.7 41 QAM 256 2
4 154000000 6.8 41 QAM 256 3
5 162000000 6.8 41 QAM 256 4
6 170000000 6.8 41 QAM 256 5
7 178000000 7 40 QAM 256 6
8 186000000 7.2 41 QAM 256 7
9 194000000 7.4 41 QAM 256 8
10 202000000 7.4 41 QAM 256 9
11 218000000 7.6 42 QAM 256 11
12 226000000 7.5 42 QAM 256 12
13 234000000 7.4 42 QAM 256 13
14 242000000 7.3 42 QAM 256 14
15 250000000 6.8 41 QAM 256 15
16 258000000 6.6 41 QAM 256 16
17 266000000 6.4 41 QAM 256 17
18 274000000 6.3 41 QAM 256 18
19 282000000 6.2 41 QAM 256 19
20 290000000 6.1 41 QAM 256 20
21 298000000 5.8 41 QAM 256 21
22 306000000 5.8 41 QAM 256 22
23 314000000 5.9 41 QAM 256 23
24 322000000 6.1 41 QAM 256 24
25 330000000 6.1 41 QAM 256 25
26 338000000 6.2 41 QAM 256 26
27 346000000 6.1 41 QAM 256 27
28 354000000 6.2 41 QAM 256 28
29 362000000 6.5 41 QAM 256 29
30 370000000 6.5 41 QAM 256 30
31 378000000 6.3 41 QAM 256 31
1 Locked 41 0 0
2 Locked 41 0 0
3 Locked 41 0 0
4 Locked 41 0 0
5 Locked 41 0 0
6 Locked 41 0 0
7 Locked 40 0 0
8 Locked 41 0 0
9 Locked 41 0 0
10 Locked 41 0 0
11 Locked 42 0 0
12 Locked 42 0 0
13 Locked 42 0 0
14 Locked 42 0 0
15 Locked 41 0 0
16 Locked 41 0 0
17 Locked 41 0 0
18 Locked 41 0 0
19 Locked 41 0 0
20 Locked 41 0 0
21 Locked 41 0 0
22 Locked 41 0 0
23 Locked 41 0 0
24 Locked 41 0 0
25 Locked 41 0 0
26 Locked 41 0 0
27 Locked 41 0 0
28 Locked 41 0 0
29 Locked 41 0 0
30 Locked 41 0 0
31 Locked 41 0 0
11-03-2023 18:46:37 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=c***;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:46:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:35:33 notice REGISTRATION COMPLETE - Waiting for Operational status
11-03-2023 18:35:27 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****:2e;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:35:22 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:35:18 notice TLV-11 - unrecognized OID;CM-MAC=****;CMTS-MAC=****CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:35:16 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:35:14 notice Honoring MDD; IP provisioning mode = IPv4
11-03-2023 18:35:04 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:34:46 critical Cable Modem Reboot via RG reboot command
11-03-2023 18:20:14 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2023 18:20:02 critical Cable Modem Reboot via RG reboot command
10-03-2023 17:22:56 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
10-03-2023 17:22:39 critical Cable Modem Reboot via RG reboot command
10-03-2023 16:54:07 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
10-03-2023 16:53:55 critical Cable Modem Reboot via RG reboot command
10-03-2023 16:37:08 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
10-03-2023 16:37:07 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1;
10-03-2023 16:36:47 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=****1;CM-QOS=1.1;CM-VER=3.1;
I've had it in and out of router mode a couple of times so i'm not sure if some of the errors are due to that. Using the Hub 5
