3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
3.1 downstream power level is too high. You will need an engineer visit to put this right. Best to ring VM on or just after 8am or alternatively you can wait here for a Virgin staff member to pick it up, typically between 5-10 days, sometimes sooner, sometimes later depending on how busy they are.
