on 12-09-2023 10:37
I'm on Volt M500 Fibre Broadband since Feb 23.
Download speed is 540Mbps + ! (great)
Upload speed when I first signed up was about 36Mbps. The I got an email in May saying my upload speed was being increased to 50Mbps. This lasted until July. Now my upload speed has gone DOWN to 13Mbps.
I've done all the testing, unplugging, restarting etc, but makes now difference.
I use wifi for my laptop, ethernet for imac.
Why has my download speed gone down so much? I work from home so this is making a big difference to me.
on 14-09-2023 13:03
Hi @droidmarsh
Thanks for posting on our community forum and sorry to hear about the issues with your broadband speed.
Have you noticed any improvement with the upload speeds via your Ethernet connection now?
on 14-09-2023 13:14
Hi Travis, thanks for your reply.
Just did a speed test. It jumped up to 36.8 momentarily, now back down to 17.7Mbps.
I wish I knew why I can't get 50Mbps again. Nothing's changed with my kit.
on 14-09-2023 16:29
Post up the data from the Hub - just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 15-09-2023 08:25
1 | 370000000 | 5.3 | 41 | QAM 256 | 30 |
2 | 138000000 | 5.3 | 40 | QAM 256 | 1 |
3 | 146000000 | 5.3 | 40 | QAM 256 | 2 |
4 | 154000000 | 5.3 | 40 | QAM 256 | 3 |
5 | 162000000 | 5.4 | 41 | QAM 256 | 4 |
6 | 170000000 | 5.3 | 40 | QAM 256 | 5 |
7 | 178000000 | 5.3 | 40 | QAM 256 | 6 |
8 | 186000000 | 5.4 | 40 | QAM 256 | 7 |
9 | 194000000 | 5.6 | 40 | QAM 256 | 8 |
10 | 202000000 | 5.6 | 40 | QAM 256 | 9 |
11 | 210000000 | 5.8 | 41 | QAM 256 | 10 |
12 | 218000000 | 5.8 | 41 | QAM 256 | 11 |
13 | 226000000 | 5.8 | 41 | QAM 256 | 12 |
14 | 234000000 | 5.7 | 41 | QAM 256 | 13 |
15 | 242000000 | 5.5 | 41 | QAM 256 | 14 |
16 | 250000000 | 5.4 | 41 | QAM 256 | 15 |
17 | 258000000 | 5.4 | 41 | QAM 256 | 16 |
18 | 266000000 | 5.3 | 40 | QAM 256 | 17 |
19 | 274000000 | 5.1 | 40 | QAM 256 | 18 |
20 | 282000000 | 5 | 40 | QAM 256 | 19 |
21 | 290000000 | 5 | 40 | QAM 256 | 20 |
22 | 298000000 | 5 | 40 | QAM 256 | 21 |
23 | 306000000 | 5 | 40 | QAM 256 | 22 |
24 | 314000000 | 4.9 | 40 | QAM 256 | 23 |
25 | 322000000 | 5 | 40 | QAM 256 | 24 |
26 | 330000000 | 4.9 | 40 | QAM 256 | 25 |
27 | 338000000 | 5 | 40 | QAM 256 | 26 |
28 | 346000000 | 5 | 40 | QAM 256 | 27 |
29 | 354000000 | 5.1 | 40 | QAM 256 | 28 |
30 | 362000000 | 5.2 | 41 | QAM 256 | 29 |
31 | 378000000 | 5.2 | 40 | QAM 256 | 31 |
1 | Locked | 41 | 332 | 0 |
2 | Locked | 40 | 8 | 0 |
3 | Locked | 40 | 309 | 119 |
4 | Locked | 40 | 276 | 44 |
5 | Locked | 41 | 287 | 26 |
6 | Locked | 40 | 252 | 30 |
7 | Locked | 40 | 163 | 56 |
8 | Locked | 40 | 144 | 57 |
9 | Locked | 40 | 212 | 19 |
10 | Locked | 40 | 274 | 74 |
11 | Locked | 41 | 273 | 30 |
12 | Locked | 41 | 364 | 37 |
13 | Locked | 41 | 360 | 31 |
14 | Locked | 41 | 546 | 30 |
15 | Locked | 41 | 483 | 27 |
16 | Locked | 41 | 464 | 53 |
17 | Locked | 41 | 468 | 26 |
18 | Locked | 40 | 595 | 41 |
19 | Locked | 40 | 555 | 25 |
20 | Locked | 40 | 345 | 22 |
21 | Locked | 40 | 105 | 0 |
22 | Locked | 40 | 159 | 37 |
23 | Locked | 40 | 135 | 23 |
24 | Locked | 40 | 129 | 19 |
25 | Locked | 40 | 131 | 14 |
26 | Locked | 40 | 474 | 2 |
27 | Locked | 40 | 403 | 0 |
28 | Locked | 40 | 187 | 0 |
29 | Locked | 40 | 199 | 0 |
30 | Locked | 41 | 194 | 0 |
31 | Locked | 40 | 262 | 0 |
0 | 46200000 | 41 | 5120 | QAM 16 | 3 |
1 | 39400000 | 41 | 5120 | QAM 16 | 4 |
2 | 32600000 | 41 | 5120 | QAM 16 | 5 |
3 | 23600000 | 41 | 5120 | QAM 16 | 11 |
0 | ATDMA | 0 | 0 | 17 | 0 |
1 | ATDMA | 0 | 0 | 29 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 16 | 0 |
14-09-2023 23:01:55 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC= |
13-09-2023 12:05:28 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC= |
12-09-2023 12:17:54 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
12-09-2023 12:17:47 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc: |
12-09-2023 12:17:35 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc: |
12-09-2023 12:17:33 | notice | Honoring MDD; IP provisioning mode = IPv4 |
12-09-2023 12:17:28 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
12-09-2023 12:17:18 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc: |
12-09-2023 12:17:07 | critical | Cable Modem Reboot due to power button reset |
08-09-2023 12:34:41 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc: |
08-09-2023 12:34:41 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc: |
08-09-2023 12:34:41 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=cc: |
08-09-2023 12:34:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
08-09-2023 12:34:39 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=cc: |
08-09-2023 12:34:39 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc: |
08-09-2023 12:33:31 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc: |
06-09-2023 20:21:47 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc: |
04-09-2023 19:17:55 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc: |
01-09-2023 13:27:39 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc: |
01-09-2023 10:22:58 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=cc: |
01-09-2023 10:22:46 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc: |
01-09-2023 10:22:35 | critical | Cable Modem Reboot due to power button reset |
29-08-2023 02:12:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
29-08-2023 02:12:52 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc: |
29-08-2023 02:10:58 | critical | Cable Modem Reboot from SNMP |
26-08-2023 20:35:27 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc: |
26-08-2023 20:35:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
26-08-2023 20:35:25 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc: |
26-08-2023 20:34:07 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
26-08-2023 20:34:06 | critical | Ranging Request Retries exhausted;CM-MAC=cc: |
26-08-2023 20:34:06 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=cc: |
26-08-2023 20:31:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc: |
on 17-09-2023 12:31
Hi droidmarsh,
Thank you for reaching out to us in our community and welcome back, sorry to see you are not receiving your expected upload speeds, I was able to locate you on our system with the details we have for you and cannot see any issues which may be causing this.
With our Hub 4.0 and 5 we recommend using Sam Knows for speed test and not speedtest.net.
Paul.
17-09-2023 13:41 - edited 17-09-2023 13:42
Are you joking?!
Look at the HUB stats (QAM levels off, T3 timeouts, all showing in the logs above):
Unless a local outage has been fixed since Friday?
on 19-09-2023 14:12
Thanks for coming back to us carl_pearce, are you still having the same issues at the moment?
Kind Regards,
Steven_L
on 19-09-2023 14:30
Carl was highlighting the OP's stats. He is not affected himself.
on 19-09-2023 14:48
I can confirm I am getting the expected speeds (up and down). So I don't know what's happened but it seems to be fixed now.
BTW, why would SamKnows be better than speedtest.net? They show different results (SamKnows showing better upload speeds).
