BWG
  • 77
Message 1 of 5
Very slow upload speed
I'm connecting via ethernet and have started getting very slow upload speeds.
Download is fine as can be seen on the Speedtest screenshot below.
Router Stats pasted in below. Superhub 3.
I'm in the HP4 area. Is there a know problem which could be causing this?
Brian
Cable Modem Status
Item Status Comments
475000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
Downstream
1 475000000 -10.7 37 256 qam 9
2 411000000 -10.5 37 256 qam 1
3 419000000 -10.7 37 256 qam 2
4 427000000 -10.7 37 256 qam 3
5 435000000 -11 37 256 qam 4
6 443000000 -11.2 37 256 qam 5
7 451000000 -11.2 37 256 qam 6
8 459000000 -11 37 256 qam 7
9 467000000 -11 37 256 qam 8
10 483000000 -10.5 37 256 qam 10
11 491000000 -10.7 37 256 qam 11
12 499000000 -10.7 37 256 qam 12
13 507000000 -10.9 37 256 qam 13
14 515000000 -11 37 256 qam 14
15 523000000 -11.4 36 256 qam 15
16 531000000 -11.7 36 256 qam 16
17 539000000 -12 36 256 qam 17
18 547000000 -12 36 256 qam 18
19 555000000 -12.5 36 256 qam 19
20 563000000 -12.5 36 256 qam 20
21 571000000 -12.5 36 256 qam 21
22 579000000 -12.7 36 256 qam 22
23 587000000 -12.7 36 256 qam 23
24 595000000 -13 36 256 qam 24
1 Locked 37.3 292 0
2 Locked 37.3 407 0
3 Locked 37.3 375 0
4 Locked 37.6 333 0
5 Locked 37.6 522 0
6 Locked 37.3 319 0
7 Locked 37.6 324 0
8 Locked 37.3 428 0
9 Locked 37.3 277 0
10 Locked 37.3 330 0
11 Locked 37.6 146 0
12 Locked 37.6 890 0
13 Locked 37.6 256 0
14 Locked 37.3 178 0
15 Locked 36.6 233 0
16 Locked 36.6 810 0
17 Locked 36.6 331 0
18 Locked 36.6 904 0
19 Locked 36.3 371 0
20 Locked 36.6 602 0
21 Locked 36.6 594 0
22 Locked 36.3 631 0
23 Locked 36.6 499 0
24 Locked 36.6 1011 0
Upstream
1 46200000 51 5120 64 qam 1
2 25799922 51 5120 64 qam 4
3 39399927 51 5120 64 qam 2
4 32600030 51 5120 64 qam 3
1 ATDMA 0 0 6 0
2 ATDMA 0 0 4 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 2 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt078-b.cm
SFID 1184448
Max Traffic Rate 690000278
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 1184447
Max Traffic Rate 44000278
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
26/01/2021 16:44:12 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 16:43:45 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 09:26:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 22:05:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 21:26:50 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 13:42:28 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 09:26:49 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:34:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 21:26:48 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 12:02:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 19:26:38 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 04:23:50 notice SW download Successful - Via NMS
08/01/2021 04:22:0 notice SW Download INIT - Via NMS
07/01/2021 18:35:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 10:26:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 12:14:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 22:26:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 18:25:9 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 10:26:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
BWG
  • 77
Message 2 of 5
Re: Very slow upload speed
Anyone from VM able to take a look at the above?
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 3 of 5
  • Downstream power levels out of spec (-6 to +10 is in spec, 0dB optimal).
  • Upstream power levels are very high.
You need an engineer visit to correct the power levels at the cabinet.
BWG
  • 77
Message 4 of 5
Thanks.
If I've understood correctly the problem is at street rather than house level? If that's the case how do I request for an engineer to adjust the power levels in the cabinet?
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 5 of 5
@BWG wrote:
Thanks.
Unless you've got one of these devices fitted between the HUB and cable to the wall socket there is nothing you can do yourself to fix it:
Yes the engineer would have to access the local cabinet and adjust the power levels from there.
You'll need to contact VM to arrange this.
