jimrat
Very slow upload speed less than 10Mbps
For a while I have been having problems with Zoom meetings when working from home, and the kids have been compaining about glitchy gaming over the internet.
I ran a speed test back in August and we're getting 80Mbps download but only 9Mbps upload speed.  I've repeated the test several times since then and it is consistently at this level, day-and-night.
It's the same whether wired or wireless connection, and with all devices.  There are no service status issues in the area, and I've done a hard reset of the router (Hub 3.0). All connections are tight.
I searched this forum and found posts about signal levels being too high.  I checked the router status (192.168.0.1) and the levels looked OK.
Any ideas?  Is it the Hub?
Jim
-tony-
  • 16.91K
  • 1.32K
  • 4K
Re: Very slow upload speed less than 10Mbps
first question what package are you on - worth posting the levels just to let others comment
you are not commenting on 80 down so wondering if you are 100 - if so 10 up is correct
____________________
Tony
jimrat
I'm on the M100 package
Jim
jimrat
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
4.3
37
256 qam
24
2
203000000
4
38
256 qam
9
3
211000000
4
38
256 qam
10
4
219000000
4
38
256 qam
11
5
227000000
4
38
256 qam
12
6
235000000
3.9
38
256 qam
13
7
243000000
3.7
38
256 qam
14
8
251000000
3.7
38
256 qam
15
9
259000000
3.7
38
256 qam
16
10
267000000
3.9
38
256 qam
17
11
275000000
4
38
256 qam
18
12
283000000
4.1
38
256 qam
19
13
291000000
4.1
38
256 qam
20
14
299000000
4.5
38
256 qam
21
15
307000000
4.5
38
256 qam
22
16
315000000
4.4
38
256 qam
23
17
363000000
3.5
37
256 qam
25
18
371000000
3.5
37
256 qam
26
19
379000000
3.4
37
256 qam
27
20
387000000
3.2
37
256 qam
28
21
395000000
3.2
37
256 qam
29
22
403000000
3
37
256 qam
30
23
411000000
3.2
37
256 qam
31
24
419000000
3
36
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
200
0
2
Locked
38.6
6154
30
3
Locked
38.6
5327
26
4
Locked
38.9
3989
49
5
Locked
38.9
3345
8
6
Locked
38.9
2516
15
7
Locked
38.6
1495
13
8
Locked
38.9
1122
0
9
Locked
38.9
703
0
10
Locked
38.9
542
0
11
Locked
38.6
568
4
12
Locked
38.6
649
0
13
Locked
38.6
492
0
14
Locked
38.6
372
0
15
Locked
38.6
271
0
16
Locked
38.6
251
0
17
Locked
37.6
397
0
18
Locked
37.3
251
0
19
Locked
37.3
214
0
20
Locked
37.3
166
0
21
Locked
37.6
154
0
22
Locked
37.6
203
1
23
Locked
37.3
349
0
24
Locked
36.6
238
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700014
42
5120
64 qam
2
2
60300000
42.5
5120
64 qam
1
3
39400000
40.8
5120
64 qam
4
4
46200000
41.3
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
8
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
3
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID
270314
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
270313
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
-tony-
  • 16.91K
  • 1.32K
  • 4K
levels are good - maybe a bit of noise on the line from the pre rs error count - they might be historical - to clear them reboot the hub and see if they rise again
your upload speed is set to 10 in the config which is correct - so you are getting that or there abouts if i understand correctly
if you want better then you would have to increase your package - 200 down gives 20 up
Tony
jimrat
Thanks Tony
The speed tester I am using (uswitch) implied that 9 Mbps is way below average - I assumed it was 100Mbps both directions.
Is 10Mbps upload enough for the kids gaming?  The eldest plays Ark, which seems to be very hardware resource-heavy.
Cheers
Jim
