ukadling
  • 7
Message 1 of 10
Very slow upload speed in SW11
Had v slow upload speeds (often way less than 1MB) for nearly 3 weeks now.
13939958045.8512016 qam2
22579916246.3512016 qam4
34619992745.5512016 qam1
43259931145.8512016 qam3
PLEASE HELP ASAP - I need this connection for work
  • 22.5K
  • 2.41K
  • 4.02K
Message 2 of 10
Re: Very slow upload speed in SW11
Post up 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again.
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
ukadling
  • 7
Message 3 of 10
16030000024.6512016 qam1
23940046827.8512064 qam4
34620063825.3512016 qam3
45369990324.8512016 qam2
2ATDMA0010
3ATDMA00370
4ATDMA0050
ukadling
  • 7
Message 4 of 10
16030001024.4512016 qam1
23940042227.8512064 qam4
34620010225.3512016 qam3
45370004124.8512016 qam2
2ATDMA0010
3ATDMA00370
4ATDMA0050
ukadling
  • 7
Message 5 of 10
1202750000-0.740256 qam9
2210750000-0.740256 qam10
3218750000-0.740256 qam11
4226750000-0.740256 qam12
5234750000-0.540256 qam13
6242750000-0.540256 qam14
7250750000-0.440256 qam15
8258750000-0.540256 qam16
9266750000-0.540256 qam17
10274750000-0.540256 qam18
11282750000-0.240256 qam19
12290750000040256 qam20
132987500000.240256 qam21
14306750000040256 qam22
15314750000040256 qam23
16322750000040256 qam24
17330750000-0.440256 qam25
18338750000-0.440256 qam26
19346750000-0.540256 qam27
20354750000-0.540256 qam28
21362750000-0.440256 qam29
22370750000-0.540256 qam30
23378750000-0.738256 qam31
24386750000-0.738256 qam32
1Locked40.370
2Locked40.3170
3Locked40.960
4Locked40.370
5Locked40.380
6Locked40.3110
7Locked40.370
8Locked40.980
9Locked40.3250
10Locked40.3120
11Locked40.3100
12Locked40.360
13Locked40.350
14Locked40.9100
15Locked40.3100
16Locked40.340
17Locked40.3320
18Locked40.390
19Locked40.360
20Locked40.3220
21Locked40.390
22Locked40.390
23Locked38.9110
24Locked38.9160
ukadling
  • 7
Message 6 of 10
https://www.thinkbroadband.com/broadband/monitoring/quality/share/53bfc62e69be0331e1fe388008ac9306d3449242
ukadling
  • 7
Message 7 of 10
22/04/2021 09:31:22criticalNo Ranging Response received - T3 time-out;CM-MAC=S-MAC=03;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 09:21:40noticeLAN login Success;CM-MAC=a:17;CMTS-MAC=01a:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:28:16criticalNo Ranging Response received - T3 time-out;CM-MAC=ac:;CMTS-MAC=a:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:35Warning!Lost MDD Timeout;CM-MAC=e:17;CMTS-MAC=0:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:30Warning!RCS Partial Service;CM-MAC=a:17;CMTS-MAC=0:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=:de:17;CMTS-MAC=:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:30Warning!RCS Partial Service;CM-MAC=:17;CMTS-MAC=0:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=:17;CMTS-MAC=:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 22:00:30Warning!RCS Partial Service;CM-MAC=a:17;CMTS-MAC=0:1a:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 21:07:14criticalNo Ranging Response received - T3 time-out;CM-MAC=:17;CMTS-MAC=0:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 21:02:19noticeLAN login Success;CM-MAC=:17;CMTS-MAC=:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 10:38:15criticalNo Ranging Response received - T3 time-out;CM-MAC=:de:17;CMTS-MAC=:1a:73;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 10:37:0Warning!RCS Partial Service;CM-MAC=:17;CMTS-MAC=:73;CM-QOS=1.1;CM-VER=3.0;
18/04/2021 17:36:25criticalNo Ranging Response received - T3 time-out;CM-MAC=:17;CMTS-MAC=:1a:73;CM-QOS=1.1;CM-VER=3.0;
18/04/2021 14:33:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=a;CMTS-MAC=73;CM-QOS=1.1;CM-VER=3.0;
  • 22.5K
  • 2.41K
  • 4.02K
Message 8 of 10
Its an upstream power issue all are well below the recommended minimum level and they are struggling - note the qam dropping from 64 down to 16 and the T3 errors.
I will flag for a VM person to come here and comment - but it would be worth calling it in as a fault asap as only a Tech visit will sort this.
ukadling
  • 7
Message 9 of 10
Thank you
Ashleigh_C
  • 633
  • 24
  • 56
Message 10 of 10
Hi there @ukadling
Thank you so much for your post and I am so sorry to hear that you are suffering with this issue.
I have been unable to locate your account via the information from your forum account, so I'm going to shoot you a PM so we can look into this in more detail. Please keep an eye out for the purple envelope in the top right of your screen to alert you to a new message.
Ash_C
