SchteeTay
Just browsing
Very slow upload on M100 Fibre
Hi there. My upload speed is incredibly bad (generally ~0.8mbit/s) most of the day, which is making work calls and other upload-heavy things I do for work very difficult.
I've gone through all of Virgin's status check/try unplugging everything etc to no joy. I've set up a BQM and it looks as bad it feels
There's some obvious correlation between the hours and what I'd expect are peak working from home hours, so I'd guess it's congestion but is there anything that can be done?
Thanks!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Very slow upload on M100 Fibre
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
SchteeTay
Just browsing
Live BQM: https://www.thinkbroadband.com/broadband/monitoring/quality/share/cb1e873c3edef7765af6aeb4a31db47365...
1411000000538256 qam1
2419000000538256 qam2
34270000005.138256 qam3
44350000005.538256 qam4
54430000005.438256 qam5
64510000005.538256 qam6
74590000005.538256 qam7
84670000005.438256 qam8
9475000000538256 qam9
104830000005.138256 qam10
11491000000538256 qam11
12499000000538256 qam12
135070000005.138256 qam13
145150000005.138256 qam14
15523000000538256 qam15
165310000004.638256 qam16
175390000004.538256 qam17
185470000004.138256 qam18
195550000004.538256 qam19
205630000004.838256 qam20
215710000004.638256 qam21
225790000004.338256 qam22
235870000004.538256 qam23
24595000000438256 qam24
1Locked38.9260
2Locked38.6370
3Locked38.6260
4Locked38.9410
5Locked38.6460
6Locked38.9540
7Locked38.6310
8Locked38.6280
9Locked38.9290
10Locked38.9290
11Locked38.6230
12Locked38.9750
13Locked38.6420
14Locked38.6270
15Locked38.6270
16Locked38.6340
17Locked38.6480
18Locked38.6450
19Locked38.6500
20Locked38.6374
21Locked38.9360
22Locked38.6230
23Locked38.9310
24Locked38.9340
14620000041512064 qam1
22579984040.5512016 qam4
33940000040.7512016 qam2
43260000040.5512016 qam3
3ATDMA0010
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Your >> BQM << is showing typical signs of over utilisation.
A good friend of the forums @Andruser has commented on the forum about similar problems to yours ...
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
The red on the later points of the graph this morning is a bit weird.
At the top of the next hour, try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight by slackening off and then retightening.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check your BQM in half an hour or so.
