psonani
  • 8
Very slow speed
I have got 100Mbps connection but speed is <2Mbps.
Tried all the combination of testing like keeping only ethernet connection and test, reset the router and test but still it does not work.
Prakash
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Very slow speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
