Allhar
Very slow speed (max 10mb when should be 50)
Hello
I am only getting speeds of max 10MB, even when I only have one device connected and am right next to the router. Been having the problem for a while and not sure what can be done
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Very slow speed (max 10mb when should be 50)
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Paul_DN
  • 6.29K
  • 360
  • 653
Hi Allhar
Thank you for reaching out tomus in our community and welcome, I am sorry to hear you aren't getting your expected speeds.
I have had a look our end and cannot see any issues at all, in order to get a better speed reading I advise to put the router in modem mode and connect a wired device with a gigabit network card using a cat 6 or above cable.
Paul.
