  • 5
Fem
Message 1 of 5
Very slow speed and hub constantly resets itself
For some time I have experienced very slow speeds and the hub 2 regularly resets itself causing 3 or 4 minute drop outs.  When I first had this service it was excellent but it has gone downhill severely over the intervening period.
i have vivid 200.  I’d appreciate some advice and assistance in resolving this - the speed appears to improve when the hub resets itself - typically every few days but occasionally multiple times in a day.
  • 5
Fem
Message 2 of 5
Re: Very slow speed and hub constantly resets itself
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
267000000
275000000
283000000
291000000
299000000
307000000
315000000
323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
17
18
19
20
21
22
23
24
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
6.98
7.12
6.86
6.83
6.98
6.89
6.73
6.67
RxMER (dB)
37.36
37.94
37.36
37.36
38.26
38.26
38.26
38.26
Pre RS Errors
2861
3342
667
1163
277
964
335
298
Post RS Errors
289
284
297
965
277
964
334
297
  • 5
Fem
Message 3 of 5
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
2.0
N/A
N/A
Channel ID
90
91
N/A
N/A
Frequency (Hz)
31000000
24400000
N/A
N/A
Ranging Status
Success
Success
Other
Other
Modulation
64QAM
64QAM
N/A
N/A
Symbol Rate (Sym/sec)
5120000
5120000
N/A
N/A
Mini-Slot Size
4
2
N/A
N/A
Power Level (dBmV)
42.25
41.75
N/A
N/A
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
0
0
0
0
T4 Timeouts
0
0
0
0
First Time
Last Time
Priority
Error Number
Description
20/04/2019 06:58:38 GMT
Warning (5)
66050310
Auth Success - Web login successful.
18/04/2019 17:00:54 GMT
Error (4)
68010302
DHCP WAN IP - XX.XX.XXX.XX
18/04/2019 16:59:53 GMT
Error (4)
68000407
TOD established
Time Not Established
Notice (6)
84000510
Downstream Locked Successfully
18/04/2019 16:47:35 GMT
Error (4)
68010302
18/04/2019 16:46:44 GMT
Critical (3)
82000200
No Ranging Response received - T3 time-out
18/04/2019 16:46:35 GMT
Error (4)
68000407
TOD established
Notice (6)
84000510
18/04/2019 16:40:51 GMT
Error (4)
68010302
18/04/2019 16:39:49 GMT
Error (4)
68000407
TOD established
Notice (6)
84000510
18/04/2019 16:35:48 GMT
Error (4)
68010302
18/04/2019 16:34:47 GMT
Error (4)
68000407
TOD established
Notice (6)
84000510
18/04/2019 16:30:46 GMT
Error (4)
68010302
18/04/2019 16:29:40 GMT
Error (4)
68000407
TOD established
Notice (6)
84000510
18/04/2019 12:29:34 GMT
Error (4)
68010302
18/04/2019 12:28:28 GMT
Error (4)
68000407
TOD established
Notice (6)
84000510
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 4 of 5
Your stats are fine, but unfortunately the logs are showing a few reboots, but may be manual reboots as there is nothing in the logs showing the local circuit dropping. This maybe due to the logs not covering a long enough timespan.
The SH2 can be a bit flaky, so I would reset the Hub back to Factory settings  just to refresh the firmware to clear any minor corruptions.
I would start a Broadband Quality Monitor to check if the local circuit is dropping. You will need to enable Respond to ICMP Timeout Echo Requests in the Advanced Settings > Tools > Ping section of the Hub's GUI.
  • 5
Fem
Message 5 of 5
OK thanks - I'll try that.  I have not manually rebooted my hub for about 6 months so any reboots are all carried out by the hub itself
