Mickc1967
  • 5
Very slow m500 speed
We are on the M500 broadband and for the last 24 hours we are lucky if we are getting 200 mbps, i have checked all the connections an even done a reset of the router an still the same, i tried ringing up to report this an it says we can see you have a fault please enter a mobile number so we can send you a link, i enter my mobile number an the line just goes dead, so thats faulty aswell, so im basicly going to have to pay for a faulty service as i cant get through to anyone.
jb66
  • 12.27K
  • 911
  • 1.78K
Re: Very slow m500 speed
Are you testing the speed properly?
Mickc1967
  • 5
Yes even borrowrd a laptop an hardwired it, when i rang 150 went to faults it did a check an said we have got a fault, but as theres noone to tske calls i cant report it properly
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Then
Can you please
Mickc1967
  • 5
I will borrow a laptop an get that info for you, just tried to do it with my phone but it wont let me copy an pastes an it was only showing the 2.4ghz info not both
Tom_F
  • 3.4K
  • 204
  • 437
Hi Mickc1967, thanks for getting in touch - sorry for the delay getting back to you,
I'm also sorry to hear you've been having some issues with your speeds as well. I've taken a look and the account appears to be fine provisioning-wise and there are no known faults or obvious issues either. Other than some WiFi-related coverage issues everything appears to be functioning fine.
If you're still having problems at this stage please get back to us with the bqm/hub data requested above and we'll be in a better position to help get things sorted.
Tom
