djmattc
  • 12
Message 1 of 8
Very slow internet speed since fault was "resolved"
Hello
I am getting really fed up with an intermittent fault I've had all day.
8AM this morning my internet was painfully slow, showing packetloss. No issues on the VM website. However, about an hour later VM acknowledged the fault in the area and said the fix would be 15:00. About 15:30 I got a text saying the fault had been fixed, but it hadn't.
I use modem only mode with the VM router and use pfSense as my router and I work in a technical environment so I know a lot about this and I'm sure this is not an issue on my side. After wasting an hour on the phone with VM I got cut off while they tried to transfer me.
Still 12 hours later, still the same fault although VM don't appear to care.
The packetloss is about 10-30% and it's been like that for hours now. A speed test always reports less than 1Mb download, and normal upload (about 33Mbs). Given the fact the upload is fine, I suspect this is nothing to do with a physical issue on my side.
Can anyone help me?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Very slow internet speed since fault was "resolved"
Then
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Then
Can you please
djmattc
  • 12
Message 3 of 8
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
The BQM is showing all red, quite possibly the Hub is not responding to Ping. Can you log in to the Hub settings and set up the Firewall as shown below ...
Hub-3-Firewall
djmattc
  • 12
Message 5 of 8
The firewall options are not there, presumably because I am using modem only mode?
One thing I just noticed is that even locally, the page did not load at first, then it look a long time to load and then again to log in.
djmattc
  • 12
Message 6 of 8
By the way, pfSense is set to respond to ping on the WAN interface and I have just confirmed this.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 8
Try setting up a new BQM.
djmattc
  • 12
Message 8 of 8
Thanks for your help.
The connection appears normal now.
